Code Publication Date
We're analyzing old undocumented vessels against Codes that were in effect at the time of their construction.  Can anyone tell me when ASME BPVC Sec VIII Div 2 was initially published?
Larry
RE: Code Publication Date
There are good summaries of Code contents, and information about how to order, but no historical/revision information.
Larry
Section VIII was split into Div. 1 and Div. 2 beginning with the 1968 edition. Anything built to the '65 code (with addenda) was simply Section VIII (no Division).
jt
I have a 1965 Section VIII code book that states this section was adapted in 1925; Revised 1927, 1930, 1931, 1932, 1934, 1935, 1937, 1940, 1943, 1946, 1949, 1950, 1952, 1956, 1959, 1962, 1965.
Don't know the later numbers.
jte and unclesyd,
Thanks much.  Those are the dates I was interested in.
BTW, I have an old code,
API-ASME CODE
For the Design, construction, Inspection, and Repair
UNFIRED PRESSURE VESSELS for
PETROLEUM LIQUIDS AND GASES
THIRD EDITION
1938
Larry
