16'' sch 80 pipe /batering
16'' sch 80 TP 316/316L  Stainles Steel  pipe  has been cutted 12 mm  short an we do not have any additional material..So that i would like to make welding filling with  the ER 316 L welding wire or suitable electrode from pipe end to provide at least 10 mm filling   in order the get requested pipe dimension. As i know it is call as  bathering..is there any part of ASME  spec?
What is the allowlable limit this option?
RE: 16'' sch 80 pipe /batering
It's called "buttering" and the limit on thickness of the "butter" layer should be the maximum thickness of weld deposit qualified by the PQR. Typically 2 times the deposit thickness used in the procedure qualification.
