ACAD 2005 - MULTI SELECT OBJECTS
I HAVE A DRAWING WITH MAYBE 50,000 POLYLINE OBJECT ALL ON ONE LAYER. THESE ARE CONTOUR LINES (WITH EVEVATION). I NEED TO SEPERATE THE 5M LINES TO ANOTHER LAYER. HOW.
I CAN QUICK SELECT, POLYLINE, ELEVATION BUT THIS IS A BIT BORING WITH 30 DIFFERENT HEIGHTS.
ANY IDEAS USING QUICK SELECT WITH VARIOUS PROPERTIES (I TRIED FILTER USING "AND" FUNCTION BUT THAT WAS WRONG TOO)
THANKS.
RE: ACAD 2005 - MULTI SELECT OBJECTS
The problem is how to tell ACAD which polyline to put on which layer.  Sorry, you have to develop your own layers and transfer objects to that layer.  You can do this by selecting which objects you want and use the layer popup toolbar to change to that layer.
Hope this helps,
John
Does Change (ssx) [pick one of the lines] get them?
I think the method you are using is about the only way.
You could try to set the front view active, (so that you are seeing each elevation - they will just look like lines across the screen) and select everything at the proper elevations with a crossing window, if that makes sense?
It's not fancy but, if each of the 5M lines are the same layer, color, etc.  Would match properties work?  Change one your way then just pick the rest.
