bearing support
bearing support
Probably it's very simple, but I'm not able to make a bearing. The idea is this: I have 2 beams, one of the beams has a hinge on the end and partly underneath him the second beam witch is fouled, the beams are made from different materials. On the first beam there's a force. Now when I solve this, I get that the first beam is displaced, but he goes right through the second beam who doesn't has a stress nor displacement.
Probably the first doesn't know that the second has to support him. But how can I fix it?
Thank you for your support...
greets Crave
greets Crave
RE: bearing support
