GTSTRUDL v26 new features
GTSTRUDL Version 26New Features& Future Enhancements
Highland Computers
http://go.to/highlandcomput
91379716 highlandcomput@hutchcity.com
Web Page: www.gtstrudl.gatech.edu
Presentation Outline
Status of Version 26
GTSTRUDL Output Window Enhancements
New pulldowns
Modified pulldowns
Presentation Outline (cont)
New Features in Version 26
GTMenu
Dynamics
Finite Element
General
Reinforced Concrete Design
Steel Design
Steel Tables
Utilities (Scope Editor)
Installation Procedure
Prerelease Features
Future Enhancements
Demonstration of Version 26
Version 26 Status
Documentation
Release and Installation Guides, Version 26
GTSTRUDL User Guide: Getting Started, Revision 6
GTSTRUDL User Guide: Analysis, Revision 2
Verification Manual, Version 26, October 2001
Software
All applicable provisions of the U.S. NRC 10CFR21 and 10CFR50 QA/QC and Verification to be completed
Beta testing and shipping date
Will be sent out for Beta testing in August 2001.
After one month of Beta testing and making changes as a result of Beta testing, software will then undergo QA
Estimated shipping date is October 2001
Import and Export features added under File
You will be able to Import DXF files and data input files from STAAD which can then be converted into GTSTRUDL input.
You will be able to Export a DXF file which contains the model data and a CIS/2 file which contains Geometry/Loading and Results.
The new File pull-down is shown on the next slide.
Output Window (cont)Import and Export
New Dialog History (¡§dh¡¨) button to keep track of the dialogs in the current session
Allows you to quickly return to the bottom level of any pull-down menu without going through the entire tree. An example is shown on the next slide.
Output Window (cont)Dialog History (dh) Button Example
Output Window (cont)Graphical Selection of Joints, Members, and Elements
As seen at the bottom of the previous slide, you will be able to graphically select joints, members, and elements in the dialogs in the GTSTRUDL Output Window. An example is shown on the next slide.
Output Window (cont)Graphical Selection of Joints, Members, and Elements (cont)
New Data Sheet for finite element modeling data as shown below and on the next slide.
Output Window (cont)Data Sheet for Finite Element Modeling
Output Window (cont)Data Sheet for Finite Element Modeling (cont)
Columns for individual material properties such as E and Poisson may also be displayed.
You can sort by ID, Type (SBHQ6, IPLQ, etc), Thickness, and Active Status.
You can use the Filter option to limit the display to certain types of elements, thickness, or connectivity.
New Commit button under:
Modeling / Loads / New Loading Combinations
which allows you to use the newly created loading combination as Available without exiting the Load Combination dialog.
Output Window (cont)Edit Existing Load Combinations
You may now edit existing loading combinations. This new dialog is available under Modeling and then Loads as shown below:
Output Window (cont)Edit Loading Combination Dialog
Output Window (cont)New dialog for Create Automatic Load Combinations
The Store Time History and Response Spectrum Dialogs now include a plotting function to display the input time history and response spectrum data.
The Dynamic Load Dialogs also allow for the graphical display of time history and response spectrum data.
A new Dialog for the input of nonlinear spring curve data has been implemented. Included is a plotting function for the graphical display of nonlinear spring curve data. This will be shown on the next slide.
A new Dialog for the input of nonlinear spring element data has also been implemented which also contains a plotting function.
Output Window (cont)New Nonlinear Spring Curve Dialog
Output Window (cont)Nonlinear Spring Curve Display
Output Window (cont)Text Output of Model Data
A new Dialog for the text output of model data for joints, members, elements, and loads has been developed. Previously, multiple menu picks were needed. A comparison between Version 25 and 26 is shown on the next slide.
Output Window (cont)Text Output of Model Data (cont)
Output Window (cont)New Dialog for Text Output of Model Data (cont)
New Data Sheet for joint displacements
Output Window (cont)Joint Displacement Data Sheet (cont)
A new Dialog for the graphical display of time history and steady state dynamic analysis results has been implemented. Displacements, velocities, accelerations, reactions, loads, and member forces can be displayed.
The next slide shows the graphical display of time history displacements.
Output Window (cont)Graphical display of the global-X displacementvs time at Joint 16 for Dynamic Load 1
Steel Design Wizard has a new option which will perform a code check and then perform a design of any members that failed as shown on the next slide.
Output Window (cont)Steel Design Wizard
Copying and pasting in Data Sheets has been improved
You will now receive a warning in the Startup Wizard if you requested a ¡§Read Only¡¨ user dataset that doesn¡¦t exist.
The Activate/Inactivate Dialog under Modeling / Data Management now uses the standard list dialog.
GTMenu Improvements
The Menu Bar and the Button Bars have been changed. Results have been shifted from Display to a new selection on the Menu Bar. The ID button has been removed from the Button Bar and added under the Options pull-down on the Menu Bar. The Inquire button has been added to the button bar. These are shown on the next slide.
GTMenu (cont) Revised Menu and Button Bars
GTMenu (cont)Modified Create Dialog
GTMenu (cont)
Create Member Properties for table profiles has been changed:
Tables are now organized by the code, country, or type of table.
This has been done to make it easier to find the appropriate table. Now, you must select the table category first and then the available tables will be displayed.
You may still have all tables displayed.
The revised Table Sections for Member Property Groups is shown on the next slide.
GTMenu (cont)Categories for Table Member Properties
GTMenu (cont)
Automatic splitting (Split at Intersections) of newly created members upon user request
Create Members Only has been replaced by a Place Member dialog
Members may now be placed using three methods:
Connect End to End by stringing together existing joints
Connect Start and End by selecting both start and end joints
Specifying the start, length, and angle. You may specify the length of the member, the member¡¦s orientation, and then the start (either an existing joint or coordinates). The member may be placed using an offset from an existing joint.
The next slide will shown the new Place Member dialog and the Start, length, and angle dialog
GTMenu (cont)Place Member Dialog
GTMenu (cont)Member length, & angle dialog for Place Members
GTMenu (cont)
The Display Model dialog has been revised:
The Mark Properties feature will now display all Section and Material Properties by default.
The Mark Joint option now indicates that only supported dof¡¦s will be labeled.
The Orientation option has been removed under Draw Member.
The Planar Axes for two-dimensional finite elements may now be displayed under Draw Element.
The revised Draw Member dialog is shown on the next slide and the Planar Axes display is also shown.
GTMenu (cont)Display Model
GTMenu (cont)Finite element planar axes
GTMenu (cont)
Loads, and the corresponding deformed shape of the structure, generated by the Moving Load command may now be animated as the load moves across the structure. The new dialog is shown on the next slide.
GTMenu (cont)Display Model ¡V Moving Loads
GTMenu (cont)New Results pull-down
GTMenu (cont)Display Reactions
GTMenu (cont) - Display Reactions
GTMenu (cont)
A new Inquire button has been added. The user can select a joint, member, or element and have all the model data displayed in the List Output box.
Information displayed by the Inquire button in the List Output box can be selected and an edit dialog will then appear allowing you to edit the information.
GTMenu (cont)Inquire button
GTMenu (cont)Inquire and Edit Joint Data
GTMenu (cont)Output from Inquire All
GTMenu (cont)Editing using Inquire Output
Double click on the information to be edited and the appropriate edit dialog will appear. Alternatively, you could select the information to be edited and click on the edit button at the bottom of the List Output from the Inquire Output.
The next slide shows editing Joint Coordinates.
GTMenu (cont)
The number of Views that can be defined has been increased from 100 to 1000.
View information is now stored in a text file which can be restored and shared.
The view text file (GTMenu_Views.txt) can be directly edited to create views of floors, elevations, or any other window on the structure. The start of the file is shown on the next slide.
GTMenu (cont)GTMenu_Views.txt file
GTMenu (cont)
Views can now be created of any cursor created Window in the Graphical Display area. Entire members and elements which are in the window will be displayed whenever the view is activated. The new view dialogs are shown on the next slides.
GTMenu (cont)New View dialog
GTMenu (cont)New View dialog (cont)
GTMenu (cont)
In addition to the Hotkeys for zooming, rotating, and panning, new Hotkeys have been added to allow you to activate any view using the keyboard or to activate the Inquire function. Type in the view number to activate a view.
You can also orient the view by typing ¡§I¡¨ (Isometric), ¡§XY¡¨,¡¨YZ¡¨, or ¡§XZ¡¨.
Type in ¡§N¡¨ or ¡§n¡¨ to activate the cursor for the Inquire function.
GTMenu (cont)Hotkeys
GTMenu (cont)
The display of joints has been changed from an X to a solid circle. When selected, a joint will still be highlighted with an X to indicate selection.
The input file generated by GTMenu will now contain dynamic mass ¡V inertia of joints lumped or consistent, inertia of joints, and member added mass.
GTMenu (cont)Default Color Dialog
The default color dialog has been changed to cover less of the screen. The default colors have also been changed for some entities to improve black and white printing.
GTMenu (cont)
Text information on the screen and in the List Output box is now spelled out and is more understandable (fewer abbreviations).
GTMenu (cont)
The time required to bring an existing large model into GTMenu has been greatly reduced as shown below:
GTMenu (cont)Reduced time to bring a large model into GTMenu (cont)
Dynamics
A friction damper truss and spring element which includes hysteretic damping has been implemented for nonlinear dynamic analysis
Finite Elements
The Von Mises stress can now be compared directly with the yield stress from the CALCULATE AVERAGE command.
The CALCULATE RESULTANT command has been brought to release status.
General
PRINT MEMBER LENGTH SORTED command and Dialog menu option (see next slide) has been added to sort members by their length. Ascending and descending order with limits on the number of lines displayed or all members above or below a specified length.
Consistency checking now looks for at least one support joint and at least 1 restraint in each global direction.
General (cont) PRINT MEMBER LENGTH SORTED
General (cont)
STEEL TAKE OFF can now output information by profile (STEEL TAKE OFF BY PROFILE) or STEEL TAKE OFF ITEMIZE BY PROFILE.
ACI 318-99 for beams and columns will be implemented as a prerelease feature
Steel Design
Member deflection checks and redesign to satisfy user specified deflection limitations.
Code check based on 1984 Indian Standard Code.
Code name is IS800
Implemented cross sections are:
I-shapes
Channels
Single and Double Angles
Solid and Rectangular Bars
Tees
Pipes and structural tubing
Steel Design (cont)
New cross sections have been added to the EC3 code:
Solid Round bars under axial force and biaxial bending
Single angles under axial tension or compression
Double angles under axial tension or compression
Steel Design (cont)
LIST CODE CHECK command will output the same information as available under the Results pulldown in GTMenu.
Steel Shape Section Tables
Long names are now available for profiles in tables BARS, RBAR, TEESM
New Indian Standard Tables for IS800 code. The new tables are ISBEAMS, ISCOLUMN, ISCHAN, ISCHAMCP, ISEQANGL, and ISUNANGL.
¡¥TS¡¦ has been added in front of the profile names in the AISC Metric TUBESM tables.
Dashed lines from GTMenu deformed shapes and mode shapes will now appear in the Scope Editor.
Text may now be rotated after it is created.
A new Password dialog is displayed when problems with the password are found. The new dialog will use Notepad to edit the existing password, or allow you to browse for another password file.
Prerelease Features in Version 26 (Prerelease features in Version 25 which are still prerelease in Version 26)
Dynamic Analysis External File to Improve Efficiency of Dynamic Analysis Results Computation
Nonlinear Dynamic Analysis
Pushover Analysis
Prerelease Features (cont)
REFERENCE COORDINATE SYSTEM Command
LRFD Design of Pipe and Structural Tube Cross Sections ¡V additional provisions added
European Tables
Concrete Tables for Rectangular and Circular Cross Sections
Automatic Generation of Static Equivalent Earthquake Load
FORM STATIC EARTHQUAKE LOAD 10 -
¡¥RS LOAD G.1¡¦ FROM RMS OF RESPONSE -
SPECTRA LOAD ¡¥G.1¡¦
Based on FEMA Publication 273
SET ELEMENTS HASHED
Used to accelerate input file processing especially for large models
Future Enhancements
Graphically specify joints and elements to be used with CALCULATE RESULTANT
Option to draw deformed shape with curved lines for frame members
Label Values on Diagrams and Envelopes automatically ¡V max and mins
Mirror option under Copy Model in GTMenu
Future Enhancements (cont)
Graphically display plastic hinge status and other pushover information.
Click on a joint, member, and element and have more information shown in GTMenu.
Create nonlinear spring and cable information in the input file created by GTMenu.
Label values of forces at ends of members in GTMenu
Boundary outline option in GTMenu to show edges where only one finite element is attached. This is useful when model is built in pieces to be sure that the parts are connected together.
Multi-support excitation for transient analyses
Plastic Hinge & Nonlinear Member End Spring Connections in Nonlinear Dynamics
Automatic displacement control option in Pushover Analysis
Tees and channels added to LRFD2 code
Code check will check member deflections using a Physical Member
Automatic addition of maximum moment & shear location during SELECT & CHECK
ACI 318-99 for tee cross sections and walls
ACI 318-2001 design
Dialogs for reinforced concrete design ¡V design data, PROPORTION, & output of design results
Data Sheets for more results and load information
Be able to use the Model Wizard with an existing structure. Control the numbering in the Model Wizard.
Dialogs for Nonlinear cable elements
New Area Load command to automatically generate the loads on floor systems with one way decking. This command will automatically distribute the load acting on a floor to the members supporting the floor. Area loading will automatically be recomputed during analysis in the event that the geometry of the floor changed since it was first specified.
Ability to specify Area Load graphically.
Future Enhancements (cont) New User Interface
The new user interface will include selection tools (in addition to the typed list of members, joints, etc.). You will be able to graphically select joints, members, and elements using the current dialogs. The Graphical Selection available in Version 26 is Phase I of this development.
The command line interface will still be available
Future Enhancements (cont) New User Interface (cont)
Multiple windows with each window¡¦s view, labeling, and annotation able to be saved and restored.
Data Sheets and property pages will be available for editing
What do we (The CASE Center) need?
Functional specification for new features.
New structural types to add to the Model Wizard.
Other new Wizards to make it easier for you to use features (Cable analysis,¡K..)
Demonstration of GTSTRUDL 26
Demonstration of a few new features in GTSTRUDL Version 26 next.
Highland Computers
New pulldowns
Modified pulldowns
GTMenu
Dynamics
Finite Element
General
Steel Design
Steel Tables
Prerelease Features
Future Enhancements
Version 26 Status
Documentation
Software
GTMenu Improvements
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
GTMenu (cont)
Dynamics
Finite Elements
General
General (cont)
Steel Design
Code name is IS800
I-shapes
Channels
Tees
Steel Design (cont)
Steel Design (cont)
Pushover Analysis
European Tables
SET ELEMENTS HASHED
Future Enhancements
ACI 318-2001 design
