runout tolerance
runout tolerance
Why is it that a runout tolerance on a diametric feature always applies on an RFS basis; namely, size variation has no effect upon the runout tolerance compliance, if the diameter in question is a feature of size?
sds
sds
RE: runout tolerance
wouldn't that be total-runout?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Single runout = runout at any given section (2D circle zone at a point on an axis)
Total runout = runout over entire face (i.e. 3D cylinder zone)
Runout does not control size. It only controls the variation of movement when a part is revolved about a specific axis.
btrueblood:
Most texts I've read specifically say not to check runout in a V-block. A datum face's eccentricity can affect the runout reading as contact points in the V-block vary through the part's rotation.
In theory, I suppose runout can have an MMC modifier, but I have not encountered a situation where it was advisable to do so.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Circular Runout is a two dimensional, surface to an axis control. The tolerance is applied independently at each circular cross section. When applied to a surface constructed around a datum axis, circular runout will control cumulative variations of circularity and coaxiality. Unlike total runout , it doesn't control taper.
Total Runout is a three dimensional, surface to an axis control. Total runout provides a composite control of all surface elements. When applied to a surface constructed around a datum axis, total runout will control the cumulative variations of circularity, straightness, coaxiality, angularity, taper and variations in the surface.
I also second, that checking with a V-block is not a good inspection process
Runout does not care what size a piece is, only the variation from a Zero point.
In past lives we would try to always add centers to the ends of a piece we knew we would need to check runout on.
Alan M. Etzkorn
Reliability Engineer
Wabash National Corp.
www.wabashnational.com
And a fourth to that... There are tri-lobe shapes that will read 0.0 run-out in a 90deg V-block. I remember reading somewhere about using a 60deg V-block then a 90 and comparing the results.
*Without data, you're just another person with an opinion.*
Hydroformer
