error: not a valid PocketPC application
I'm trying to run a .exe of the daqmx base example Cont-Acq & Graph Voltage - Int Clk on my PDA, but I'm getting the error "Cont-Acq & Graph Voltage - Int Clk is not a valid Pocket PC application". I get this error for all the daqmx base examples that I've tried.
I was able to run these examples on my PDA when I first got started on labVIEW and daqmx base a couple weeks ago. Since then, I was experimenting with a few other labVIEW programs for PDA that don't use the daqmx base. I don't think I changed any pertinent settings. However, now none of the daqmx base examples are working on my PDA. I've read that "....not a valid Pocket PC application" is a common error when a VI isn't Built for the correct processor-- but I think I'm ok there: I'm Building for the ARM processor. Besides, if that were the problem, then my other non-daqmx base PDA executables would have given me the error as well, right?
Any thoughts on what else could cause this error?
thanks in advance,
Luan
thanks in advance,
Luan
