Force to Straighten Curved Beam
4
I have a 25' round steel rod with a diameter of 1.125".  This rod is not straight, but rather has a radius of curvature of "p". Does anyone know how to calculate the axial force necessary to straighten the rod?  I don't know a formula to determine lateral deflection in a curved beam due to axial tension.
When I say "straighten" I mean elastically deform the rod into a straight beam, not permanently yield the rod to a straight condition.
RE: Force to Straighten Curved Beam
Correct me if I'm wrong, but you sould thread this problem as a spring not a beam!
Somethig simmilar I can see on "Spotts Design of machine elements" 4-th edition on page 197 as "Belleville Spring"
may be you can use that theory, check here with other proffesionals.
What is the application for that you are describing?
I believe it requires an infinite amount of axial force to make such a beam absolutely straight, so you would first have to define some tolerance within which you considered it to be "straight".
Ditto to English's answer.  As long as you don't plastically deform it, it will just come closer and closer to straight as force is increased, but never perfectly straight.
I'll propose the following argument.
Assume your beam of length L may be considered as bent to a constant radius of curvature R (as you suggest): if that is not exactly true the following will give anyway a good approximation.
If the deflection at center with respect to a straight line joining the two ends is f then R=L2/8f and the energy that must be spent to go elastically from the bent shape to the straight one is (the same that would be required to bend it from straight to the deformed shape) W=EJL/2R2=32EJf2/L3.
In going from the deformed shape to the straight one the distance between the end points raises by ΔL=L3/24R2=8f2/3L.
Now if you call F the average value of the force by which you pull axially the beam to straighten it one has
F=WL=12EJ/L2
Hoping that all the above contains no mistake, if you take the double of that force I guess you'll be quite close to a straight shape.
prex
http://www.xcalcs.com
Online tools for structural design
Hi ryldbl
I would use a strain energy method or Castigliano's theorem
which can be found in most mechanics books.
If you assume one end is fixed and you apply your load at the other end parallel to that end face you should be able to work out the force required.
It would help if you could describe what angle the radius 'p' goes through and also the actual value of 'p'
regards desertfox
i don't know if this approach turns out the same as prex's but ...
i did like prex's observation that this is a two force member, so the bar looks like a shallow arch being pulled in tension.  it's also symetrical so you can consider just 1/2, cutting at the crest of the arch.  this end has a moment (due to the off-set).  two questions come to mind ...
the off-set is reduced as the arch flattens, reducing the moment which is the only thing trying to straighten the arch.  i suspect that the arch will want to form a plastic hinge, and will adopt a double arch shape as it is stretched.
also, this is a large displacement problem because as the displacements (that flatten the arch) have a significant impact on the internal loads.
possibly you could analyze the starting geometry, a cantilevered semi-arch.  radial sections will be sufficient to determine the internal loads along the arch.  apply the load in increments, determine the deformed shape, at some stage you'll need to reform the internal loads (depending on how you've formed the expressions (maybe you can iterate and converge on a solution for eah load step).
alternatively use some non-linear FE code (MARC).
whatever happens, i doubt that you can elastically straighten an arch (depending on your definition of straight!)
good luck
Going one step further in my reasoning, that is of course based onto energy conservation principles, one can state that the axial force that will be required to go from a deflection f to a deflection f-df is:
F=(dW/df)/(dΔL/df)
Now dW/df=64EJfdf/L3
and dΔL/df=16fdf/3L
Now making the ratio as above the term fdf cancels out and one finds that the pulling force F=12EJ/L2 is constant throughout the straightening process. Hence, contrary to what almost everyone above was expecting, the required load does not tend to infinity, it is on the contrary constant!
So I must come back on my conclusion in the preceding post: you don't need to double the value given by the equation above, just take it as F=12EJ/L2.
prex
sorry, don't buy that, mostly because the curvature of the arc (ie the offset in the ends of the semi-arch) doesn't enter into it ... and it has to (no?), are we dealing with a semi-circle or a shallow arc ?
but also the problem is non-linear (each increment in load will not have the same transverse displacement) and the displacement is large (particularly in its effect on the internal loads).  i believe that your analysis includes these assumptions, which are violated.
i did a quick linear run (a cantilevered semi-arch).  i had 1" offset between the ends, radius of beam = 50", a steel bar 1/2" radius, applied 1000 lbs and got 0.03" transverse displacement with a max stress of 12ksi; so the linear (wrong) answer is 30,000 lbs with a stress of 360 ksi (a bit above yield).
looking at your equation F = 12EI/L^2, I = A^2/(4pi),
so axial stress = F/A = 12EA/(4piL^2), about EA/L^2
then stress/E = A/L^2, or E/stress*A = L^2,
E=30Mpsi, stress=100ksi, A=1in2, then L=sqrt(30000)=173"
but you previous comments still apply (i don't think this is right)
Hang on, is anyone claiming that there is a linear elastic solution leading to a perfectly straight bar? You can disprove that in three lines or less using superposition.
Cheers
Greg Locock
Draw a straight line between the endpoints.
At any point in the rod, the moment is equal to tension at the ends times the deflection away from that line.
The curvature of the rod due to applied forces is proportional to the moment at each point.
In order to get the rod straight, the curvature has to be zero, which requires some finite moment to offset the inital curvature.  But if rod is straight, there IS no moment.  Or alternatively, as the centerline rod approaches a straight line, the required end force increases without limit.  And note that the moments at the ends of the rod are always zero, so the ends of the rod are never straight.
One problem I see with the energy method is that it assumes the rod will take a certain shape, only the assumed shape is not one that can be formed by applying end tension.  If the problem was restated as "What shape will be formed by applying end tension?", I think this would be more evident.  You could assume that rod deflected into a pretzel shape and calculate the tension required to do that using energy methods, but I don't think you'd have a meaningful result.
Energy methods.... shouldn't the beam be modeles as a continuoum.
Wes C.
As ryldbl provided all the required data, I can calculate the required load with my formula: F=1390 Newtons (sorry for not using american units). If ryldbl is able to make the measurement (hope this is not a school assignement), he could enlighten us on the result. Note that this same force, as I stated above, will be required to start straightening and to arrive to the straight beam.
For those that question this result (that surprises me the first) without providing a different route, I'll try to detail here the assumptions on which it is based.
The first assumption is that no account is made for the axial strain of the beam: this one is quite correct till the beam approaches the straight shape, after that any increase in the axial load will of course go into an axial strain.
The second assumption is that we may use the common formula for the energy of deformation in bending: W=(∫EJy'2dx)/2 the integral being extended over beam length and y being the deflection. I think no one can question this formula, that is known to work well for quite high deflections (though we are not dealing with a semi circle of course) and is valid for any deformed shape.
The third assumption is that the beam bent shape may be approximated with an arc of a circle: this one will be fairly good for most beam deflections that resemble an arc of a circle (not an S shape for instance).
The fourth assumption is that the arc is quite shallow. In this case we have the following approximations (the symbols are as in my first post above):
y'=1/R
R=L2/8f : this one comes from simple geometry and includes the approximations f<<L<<R that are of course acceptable for a shallow arc
ΔL=L3/24R2 : this one is obtained by making the difference α-sinα, 2α being the angle subtended by beam length from the center of curvature, and using the first two terms of the Taylor expansion for sinα (which is again good for a shallow arc).
From all the above, based on the relationship dW=FL (in this differential form it is of course one of the least questionable principles of the classical physics), one obtains the formula F=12EJ/L2.
In all this:
- to rb1957: you are correct that this is a problem in the so called large deformation field (that is where the stress depends on the strain), but nevertheless all the above stays correct; the proof? The large deformation theory is not linear and indeed we have (surprisingly) a constant load for a changing deformation!
- to JStephen: I too was expecting a force tending to infinite when the shape approaches the straightness, but, as you certainly know, one has to be careful when dividing two quantities that both approach zero. It is true that the lever arm of the axial force tends to zero, but the same does the resistance of the beam to bending (or in other words the energy required to deform it), and the surprising result is that the force stays constant over the whole deformation (assuming as stated above a shallow arc)
prex
prex,
"As ryldbl provided all the required data, I can calculate the required load with my formula: F=1390 Newtons (sorry for not using american units)."
um, i didn't see a radius posted (only a length (25') at some radius, p).
um, this is a solid steel (which flavour; never mind, doesn't matter much) bar 1.125" diameter ... and you're going to straighten it with a force of 1400N (= 300 lbs) ...
i don't think so ... 300psi ??? you'd get this load just by hanging the bar from one end ! (25' = 300"*1in2 = 300in3*0.3 = 90 lbf ... ok, you get only 1/3 the force !!
again i don't think you're equations account for large displacement in a non-linear problem, and i think a quick sanity check on your result bears this out.
Well rb1957 I just can't see why that load should be so inadequate: under its own weight (1/4 of that load) that same bar, when suspended horizontally at the ends, would deflect by about half a meter (being close but not beyond yield by the way).
Also what my formula says is that the load doesn't depend on the radius of curvature (provided this one is large with respect to length).
As of course I can't personally be 100% sure of a result obtained on the fly (no literature references that I know of), why don't you try to discuss the merit of my arguments or to obtain an independent result?
prex
prex,
i've run a couple of quick models. curved beams, about 30" long, 1" diameter, steel, loaded with 1,000lbs (about 3* your load).
one model had about 1" rise, and the load produced about 0.05" lateral displacement.
the 2nd model had 0.05" rise, and produced 0.0015" lateral displacement.
first, the lateral displacement is non-linear, the same force produced different effects.
2nd, the result is proportionally constant (which i thought was quite intereting).  what i mean is that in both cases the load produced a lateral displacement = 3% of the rise.
maybe i should try my models with 300" length; but basically, i think that trying to straighten something by teniosn isn't particularly effective.
i did think your fR = L^2/8 is a neat observation, and a way to avoid f and R, so long as you're always using (fR) and not f or R.  but think about the effect of 300psi (=2MPa, =1400N/625mm2) on a steel bar.
For a hanging cable, for which the formulae are readily available and discussed on other threads, there is no question that the cable cannot be made absolutely straight regardless of the tension. Although this case is slightly different, it is highly unlikely that you could straighten a beam under similar conditions, since the transverse resisting force increases as the beam becomes straighter, whereas the cable weight is constant. Although I could be wrong, without wading through the whole of Prex's derivation, it seems that the most likely error is that he has confused the y deflection in the energy integral with the y in the equation y" = 1/R, since in that equation, y and the y deflection are the same thing only for an initially straight beam.
i liked prex's approach that the work done to straighten the bar is the same as the work done to bend it.
so the external work done is applied force P, displaced by L-2Rsinx; note we can't say sinx =x (even tho' x is small) because L=2Rx.
if x = 0.01c (L=300", R=15000", f=0.75")
then delta = 0.005" (well, 0.004999975")
so the external work is 0.005P
if x = 0.1c (L=300", R=1500", f=7.49375")
delta = 0.49975006"
then the external work is about 50*x^2*P
and the internal work is ...
I'm assuming we are not speaking about a hanging cable or beam of course: that is a completely different problem. What I'm assuming is the bent bar is fully supported by a  flat horizontal table, so that beam weight has no effect: I see now that this was unspecified in the original formulation, but assume this was the intention of ryldbl, as the focus was on recovering straightness against a previously bent shape (of course in a cable this would have no meaning, as there is no bending).
And EnglishMuffin I see no confusion: y'=1/R is of course the second derivative with respect to x of the deflection y.
rb1957 I agree of course that the relationship between loads and deflection is not linear in a beam beam bent by transverse loads and with an axial one, if that is what you mean: this is a well known result (a cubic equation is found for the deflection if I recall correctly) and you can see calculation sheets for this condition in the site below.
Coming to your models, I can easily confirm your results with my formulae (though .0015" is perhaps .0025"?): for a 30" long beam your load of 1000 lbs is about 1/20th of the straightening load I calculate, and in fact your calculated lateral displacement is about 1/20th (or close to that) of the initial rise. You should apply a load 20 times higher (or use a length some 5 times higher) and you should see in both models that the residual deflection goes close to zero.
I can check your results also in a more detailed way, using only the first model for brevity.
In the initial configuration the radius of curvature is (excuse me if I will use the SI) R1=2857.5 mm and after applying the load R2=3007.9 mm.
This requires a work of deformation given by W=EJL(R2-R1)2/R14/2=544 Joules
The displacement of the end under the load (you could certainly confirm that in your calculation) is ΔL=L3(1/R12-1/R22)/24=0.22 mm
and the force to do that is F=WL=2473 N = 556 lbs
This is not exactly what you find, but it must be recognized that the radius of curvature in your first model is not really big, so there is quite a big error in differentiating 1/R2. Suppose that the second model would give a better result, can you check and confirm the data?
And thanks to you rb1957 I think I discovered an error in my second post above (not in the first one however), but I'll leave to find it as an exercise...
prex
prex,
i notice you've linearised your equations ...
f=L^2/8R is an asymtope for f=R(1-cosx)
delta = L^3/(24R^2) uses only the first two terms of the expansion of sinx (=x-x^3/6+x^5/5! ... )
maybe this distorts the math ?
Prex : There is nothing wrong with saying y" = 1/R (approximately). But that y" cannot be the same as the y" in the energy integral you have quoted - the second differential of y for a curved beam is not zero when the deflection is zero, although the value of the strain energy integral should then be zero. Whether or not you made this assumption without realizing it I do not know, but you must have made an error somewhere since your conclusion is incorrect. I repeat - it is inconceivable that you can completely straighten a bar using axial tension if you cannot completely straighten a cable !
If the bar has a uniform curvature, then the only way to bring it to exactly a straight shape is to apply end moments such that the curvature induced is exactly equal to (and opposite from) the initial curvature.  You can't do this by applying end forces.
Perhaps in your energy equations, you are assuming that the applied energy is equally distributed along the bar?  It is not, of course, the moment generated by the tension is maximum at the center and goes to zero at the ends.
The reverse problem is similar:  given an initially straight bar, apply compressive end forces to bend it into a curved shape.  Of course, it doesn't bend into exactly a cylindrical shape, because of the moment-variation problem mentioned above.  And in fitting up tank shell plates with this method, considerable work with bull pins and key plates is required to induce that end moment.  I believe your energy method would say this was not required; that X amount of force would bend it into a perfectly cylindrical shape.
I am very skeptical of a model that requires "the resistance of the beam to bending" to go to zero.
This problem does seem to me very similar to a suspended-chain problem.  If you have a suspended chain, and want to know how much tension is required to make it hang perfectly straight, you can easily calculate it using energy methods.  But in fact, as you apply more tension, you just get a flatter and flatter catenary; you don't reach some specific load where it is now "flat" and wasn't one pound before then.  The problem, once again, is that you're applying energy methods between two shapes, but one of those shapes is not achievable.
I definitely agree with JStephen.  The ludicrosity of an elastic structure with step response is mind-boggling.  This has to be a case of bad assumptions and good math triumphing over common sense.  (BTW, has anyone noticed that ryldbl is MIA?  The man starts a fire and walks away....)  Instead of this energy thing, think about it in terms of classical mechanics of materials.  What would have to happen to the structure of the bar in order for it to be straightened?  Essentially, the bar is a portion of a torus.  Assuming the mentioned radius of curvature 'p' was for the centerline of the torus, (and say 'd' is the diameter of the bar), the length of the inside "edge" of the torus portion is 2*pi*(p-(d/2)) and the length of the outside "edge" is 2*pi*(p+(d/2)).  Let's call this L1 and L2.  In order for the bar to be straight, L1 must be "stretched" equal to L2.  Therefore the gradient of the strain across a circular cross section must be constant from the inside of the radius of curvature to the outside.  That means that the stress gradient must also be constant.  I think the integrals etc to go from strain gradient to stress gradient to force required for a bar of rectangular cross section wouldn't be too bad.  A circular cross section is a bit more complicated.  I don't have time to play with either here at work, though.
Of course, if this is a real-world application, you'll have to consider how the bar was curved in the first place.  Are there residual stresses? Work hardening? Inhomogeneous properties?  Also, how the heck are you gonna hold on to this thing?  End conditions are pretty important.
Hopefully I'll play with this later if I don't lose interest.
-Josh
OK, starting with a rectangular beam of width w and thickness t (t being parallel to the radius), we can call the inside and outside lengths concentric circles.  L1 is the length of the outside and L2 is the length of the inside.  Of course, R2=R1-t. The chord lengths are proportional to the radii to the inside and outside, such that L2=(L1)(R2)/(R1).  The strain 's' required to make the inside length equal to the outside (and therefore straighten the beam) is s=(L1-L2)/L2.  Combining the above, we get s=(R1/(R1-t))-1.  Let's call this S for max strain.  This is the maximum strain at the inside of the curve when the beam is straigtened.  Of course, at this point you must stop and check the stress required to produce this strain.  If it's above the yield stress then you will move into plastic deformation.  As per my previous post, strain (and therefore stress) varies linearly across a cross section, from 0 at the outside to maximum on the inside.  Let y be an axis with origin at the outside edge going towards the center of the radius of curvature.  Then stress as a function of y is SEy/t (E=Young's).  The force P will be the integral of stress times area over the cross section of the beam (y = 0 to t).  Evaluated, this is SEwT/2.  Taking all of the formulae above and combining to express P in terms of knowns, we have P = (R1/(R1-t)-1)(Ewt/2)
Note that the actual length dropped out near the beginning.  This makes sense, because with the circular arc of the beam, everything is proportional.  Make t=0 and force required goes to 0.  Makes sense.  The larger R1 is, the smaller the force.  As R1 approaches infinity, force approaches 0.  Again, these all make sense.
Now to address the round bar issue.  To find max stress, just replace t with 2r in the above derivation, where r is the bar radius.  The biggest headache is in the integral of stress over area.  With a rectangular section, the infinitesimal area dA is w(dy).  For a circle, the infinitesimal dA=2(sqrt(r^2-(y-r)^2))dy.  I don't really care to do that integration, though!
Of course, this is neglecting any gravity effects.  If this thing is actually suspended between to ends, the catenary thing comes into play, although the actual shape will not be a catenary since a bar can support moment while a chain/rope/cable cannot.
This was fun...
-Josh
i agree josh, a fun analysis.
however, i can't believe ('cause i haven't done the sums yet) that it's impossible to straight a minutely bowed beam with a tension load; damned inefficient but impossible ?
i liked your approach about making lengths the same ... we've had energy methods, simple statics ... so many ways to skin the cat !!
thinking about your rectangular bar, side W, so the outer fiber length is 2theta(R+W) (theta is the semi-angle of the bowed beam).  as you say, this will change to be the same as the mid-fiber length (2thetat(R+W/2), a change in length of thetaW, and a strain (for the outer fiber) of thetaW/(2theta(R+W)) = W/2(R+W) = 1/2(R/W+1).  let's use a strain of 0.004 as the proportional limit, so R/W = (1/.008-1) = 124.  so that a rectangular bar bowed with a radius more than 124W can be straightened elastically, no ?
a circular bar should floow a similar result ...
Yes, I was thinking impossible at first as well by comparing to the hanging catenary principles, but when you look deeper it's definitely possible (again, assuming this thing isn't suspended in gravity).  rb1957, it looks like the W in your analysis is the t in mine.
There really needs to be some sort of sketchpad or something on this type of forum!
yeas, i was keeping t for thickness, BUT ...
we'll obviously be straining the faces in opposite directions (compressing the outer face, tensing the inner), but the applied load is axial (when the beam is straight).
well, the mid-fiber is also straining, so that the final length is 2(R+W/2)theta(1+strain); and the inner fiber will extend to this length, an extension of thetaW(1+strain)+2Rtheta*strain.  then inner fiber strain is ...
W/2R*(1+strain) +strain = 0.004 (proportional limit).
so if the axial strain (=(P/Wt)/E) is 0.002, then a beam with a bow of more than W/2*1.002/0.002 = 250.5 (a bit more than double the previous result) would be straightened by a load of 0.002*E*(Wt) !
Uh-oh.  Wait a moment.  Get it?  A moment?  We simply cannot bend a beam (straight to curve or curve to straight) without an end condition that can support some kind of moment.  Your mention of straining faces in opposite directions smacked me in the forhead with that fact.  There would have to be some kind of perfect rigid plate on the end of our rod.  Tensile force would have to be applied somewhere on this plate away from the centerline of the rod. And this is where the transition from theory to reality comes in.  Anybody have a perfect rigid plate?  Assuming we could find one, the question then becomes how far from the bar centerline you want to pull from.  As the distance from centerline to attachment increases, the proportion of fibers in compression increases, and force required goes toward 0 at some rate.
Decreasing that distance makes the proportion of fibers in compression decrease, until at some point all fibers are in tension.  At some force the attachment point will actually be on the end of the beam.  As force increases to infinity the distance from the beam centerline to the attachment point goes to 0, but of course you will yield the bar long before that.
So in the real world, we are sort of back into the realm of the impossible.  You might get close enough with a carefully designed fixture with an attachment point at some offset from the centerline.
Of course, if you pull any harder than the specified calculated force, you will bend the beam in the opposite direction.
Basically, this is what JStephen said above:
"If the bar has a uniform curvature, then the only way to bring it to exactly a straight shape is to apply end moments such that the curvature induced is exactly equal to (and opposite from) the initial curvature.  You can't do this by applying end forces."
I would append that final statement with "...at the beam centerline."
Still fun... Does it make me a complete geek to think that?
-Josh
Real World:
If the bar is bent has something yielded?
In a real world situation one approach to straightening the bar would be to apply a very slight twisting motion by some means as a force is applied to end of the bar. A collet is normally used to grip the bar a close to end as possible. This will take care of the rigid plate.
Depending on the method of manufacture some bars will rotate around the centerline axis while being bent.
josh,
no, well at least that's not the way i see it ...
i have a symmetric arch, pinned at one end, pulled at the other (normal to the axis of symmetry).  so effectively we  cantilever sagging.  i picture the applied force (and its reaction) as being on the CL.
and if you pull harder, won't you just be adding axial strain (the internal bending stresses cancel the displaced shape).
unclesyd,
maybe it was stress relieved afterwards !?
That's how I pictured it at first too.  But in order to have tensile stresses in one side and compressive in the other, there _must_ be an external moment supplied somehow.  Otherwise we are ignoring the requirement that the sum of the moments = 0.  A theoretical pinned connection is a point force incapable of supplying that moment.  Surely you can picture the FBD of a slice of the bar and see the internal moment.  The end of the bar must support that somehow.  If the bar were straight to begin with, a tensile force pinned at the center would act along the centerline of the bar.  However, the pinned arch's force acts along a straight line between the two pull points, not somehow along the centerline.  The bar will strain and straighten to an extent, but the force can never act along the centerline of the bar.
sorry handleman, "don't get your banter ..."
"That's how I pictured it at first too.  But in order to have tensile stresses in one side and compressive in the other, there _must_ be an external moment supplied somehow."
... no, the load and the reaction are co-linear; for convenience we're looking at 1/2 the arch which has a single applied force, a parallel reaction (offset at the crest of the arch) and an internal moment reacting the couple.
"Otherwise we are ignoring the requirement that the sum of the moments = 0.  A theoretical pinned connection is a point force incapable of supplying that moment.  Surely you can picture the FBD of a slice of the bar and see the internal moment.  The end of the bar must support that somehow."
... it is free body, in equilibrium.
"If the bar were straight to begin with, a tensile force pinned at the center would act along the centerline of the bar.  However, the pinned arch's force acts along a straight line between the two pull points, not somehow along the centerline."
... yes, the external forces (load and reaction are co-linear and not directed along the the arch.  the CL i was referring to is the neutral axis of the cross-section (the poster i was replying to was discussing offseting the load from the center line to create an end moment, which i don't think is required).
"The bar will strain and straighten to an extent, but the force can never act along the centerline of the bar."
... i think it can (in fairly special geometries) if the arch flattens completely.
Looking at your half-arch, the initial moment arm is the height of the arch at center, and your force and reaction are parallel and horizontal.  I'm sure you'll agree that as the bar bends toward straight it requires more and more internal moment.  But at the same time, the moment arm (arch height) is decreasing! With moment required increasing and moment arm decreasing, force is shooting off towards infinity pretty quickly.
Hmm, seems like we're going in circles, rb.  I just went back and re-read the entire thread.  My last post says almost exactly what your first post does!  What convinced you that your initial assessment was incorrect?
handleman,
i can see your point (now) about the free body of the flattened 1/2 arch.  i think the moment to flatten the arch is fixed, think about making a three-point bend load, the transverse load is easily calculated, no?
that said, the offset is reducing as load is applied so that eventually you'll have a very large force acting over a very small moment arm to create this moment.
i have a little problem saying we can't straighten any beam, what if the load was applied very quickly ? wouldn't the beam straighten ?  how about the argument about reversing the question and trying to bow a straight beam (essentially buckle the beam) ?
maybe that's the point ... the strain argument i'll been posting only considers the effects of the loading (the strains and moments) without considering how the loads are going to produce those effects.  i mean it's easy to straighten the beam with transverse loads, and this will produce the same effects we've talked about (strains, internal moments).
say we applied a very large force very quickly; if i'm right about the fixed moment required (which could be calculated by consideration of transverse loads), apply a force that'll produce a larger couple about the crest.  won't the beam straighten ? i see it working that way.  but you still have an internal stress distribution that's inconsistent with the external loading ??
handleman,
i wish i knew !
I guess if you pulled the ends fast and hard enough, you could cause the arch to flatten dynamically in a vibrational sort of way, but once the system reaches static equilibrium it will be back to some kind of bent shape.  As you said, the arch can certainly be flattened if loaded transversely, and the internal moment can easily be calculated.  However, that is the moment that must be applied to the _straightened_ arch, and you can't apply that moment without the moment arm that the curved arch supplies.
As force increases, the arch does move toward straight.  The harder you pull, the straighter it gets until you go plastic.
It is as you say, the internal stress distribution that we calculate for a straightened beam is inconsistent with the external loading conditions.
I sure wish ryldbl would chime in with some more information about the reason he asked the question in the first place.  If the end conditions are something other than pinned, we're barking up the wrong tree anyway.  Guess we just like to hear ourselves bark....
like wrestling with a pig ...
If the bar is bent has something yielded?  In a real world situation...
Presumably, if the bar was made perfectly straight and is not curved, then it has yielded.
You get the faces of the bar or plate to the yield stress when you roll it.  But it will spring back somewhat, and the residual stresses are not necessarily close to the yield point afterwards.  In other words, you could apply some amount of tension without anything yielding.
In a real world situation, this wouldn't be a problem- get 90% of the deflection out and call it done.
You could cast it to a bowed shape, nothing's yielded then.
Well, I'm glad nobody called me on the superposition thing, as I've forgotten how I did it!
Cheers
Greg Locock
Sorry, I've been out of the office for the past week.  Wow, I never would have thought there would have been so many posts...this is great! You've all come up with some enlightening theories, I wish I could have provided some more detail earlier but here it goes...
The application is a continous sucker rod string in an oil well.  For those who are unfamiliar, a contious sucker rod string is a length of steel rod ~3,000 to 7,000 ft long which is used to connect a  prime mover at surface to a pump underground.  When the rod is transported to the well site, it is wrapped onto a large spool.  When this is done, a slight amount of yielding occurs resulting in a slightly bent rod string.
It is imperative that the rod string be as straight as possible when placed in service.  Every rod string will have a certain amount of axial load applied by the sub-surface pump.  This has lead to the question: how much load is neccessary to straighten a rod with a given radius of curvature?
The 25' length was arbitrary and I only proposed it because this is the length that I am trying to get some tests done on.  My thinking was that if I could get a methodology from you all I could apply that to any length.
In short, the load conditions are:  The beam is pin supported at the top end and hangs under its own weight.  I know that the weight of the rod alone is not enough to straigten it.  I do not know the exact radius of curvature.
Can you just reverse bend it slightly as you install it to straighten it out?
There are a lot of ways that we could remove the bend, but this is a theoretical question bound by the fact that the rod is bent and there is an axial load applied.
For a "back of the envelope" ball park estimate, you might consider something like P = 8*del*E*I/(e*L^2), where E I & are the usual, del = required lateral translation at middle of length L, and e = eccentricity of axial load P. This equation is basically from Timoshenko, and is for a short thick column, assuming the rod starts from an unstressed elastic deflection shape and not a circular arc, and that it takes the same amount of force to bend it back as it did to deflect it. Obviously I cannot justify this equation rigorously on these terms, but for what you are doing, it might be a good enough indicator - at least it stands up to dimensional analysis and rough logic. The interesting thing about this equation is that the longer the rod, the less the load has to be to make the rod straight for a given mid point lateral translation, (presumably approximately within an amount "e"). What it amounts to is that for such a long rod, you may not have to worry. It all depends on what you mean by "slightly bent".
I'm glad you came back with that description as I've been looking for an article that I have on uncoiling/unwinding wire for heading machines.
I'll keep looking
i agree with unclesyd, thx for the added info ryldbl.  i think we'll have to retrace some steps, because now we have a plastically deformed rod (so there is an internal stress field) and i think the original "elastic" reference is no longer accurate, rather it should be "plastic", no?
also, surely this problem has been uncountered before, as it sounds (to the uninitiated) to be a stadnard operation.
also, is the rod really axially loaded ?  sure there is the weight to be considered, and sure the rod is being "forced" into its hole, but is "driven" a better description ... isn't the force applied to the rod being reacted dynamically (with movement of the rod) ?
i think unclesyd will come up with the answer (whihc i think is a couple of idler wheels.
EnglishMuffin, that formula comes from this one:
f=ML2/8EJ
This represents the center deflection of a simply supported beam under the action of two equal end couples M, so I suppose that in your reference the eccentricity e is at both ends of the beam, from what M=Pe.
Don't want to propose again my conclusions, that were clearly completely wrong , however note that in my first post I proposed P=24EJ/L2 for the straightening load.
However ryldbl I understand now that with such a load and no initial eccentricity (except beam deflection) one would reduce the deflection to some 20% of the initial value, so that the beam would hardly be defined as straight. The load to straighten it to say 1% is really much higher and of course it is impossible to have it fully straight.
prex
I still think that we are dealing with the elastic range. The rod has been plastically deformed slightly, but the axial force applied to the rod string should not be enough to yield the rod - only elastically straighten it somewhat.  In other words, when the axial load is removed, the rod should return to its plastically deformed, slightly curved state.
Yes, there is axial load applied to the rod.  The application considered here is not the reciprocating up and down beam pumps that you typically see in oil fields, but rather a PC pump where the rod is rotated to operate the pump.  Thus the rods is exposed to a constant torque - something which I do not want to consider in this discussion - and a significant axial pulling force caused by both rod weight and pump operation. This is key, when the pump is operational, is directly applies a large axial load to the rod string.
is the rod "freely" rotating under the torque, or does the pump react the torque, in which case there'll be a large torque wind-up (no?)
also, we're getting into the words a little more ... how much is "slightly", describing the plastic deformation ?  i suspect that the 7000' of rod is coiled for transport, say a diameter of 25', and uncoiled at the site; now we're into a non-linear model of how the rod coils and relaxes.  and how straight is "somewhat"; we've spent quite some time discussing gettting a mathematically (perfectly) straight rod from a deformed rod ... i suspect we're into another problem ... how much force is required to push the slightly deformed rod down its hole ? how much bigger is the hole (than the rod) ?
prex, you sounded a little defensive; i don't think there's any need to be, we're all trying to solve a question with little information (that's not a shot, ryldbl) and i think we're all taking our best shots and learning from them.  hopefully we're not learning not to shoot !
