Timber beam bracing
Timber beam bracing
I have a cantilevered PSL 7x20 beam, supported at two locations by PSL 7x7 columns. The problem is that my first support (not at cantilever) has lateral bracing but the support at the beginning of the cantilever has no bottom chord bracing, and cannot due to architectural constraints. Also, hidden connections must be used. My question is: can I rely on a bolted knife plate from column-to-beam to provide lateral-torsional resistance? My engineering instincts say no, but it seems that there are two mechanisms working against a torsional failure: first a tension/compression couple (tension in the knife plate, compression field between the top of column and bottom of beam on one side of the knife plate), and second, if the knife plate is thickened, bending resistance would be provided. But in either case it seems I would need to know how much lateral bending to resist. Thank you for any thoughts.
RE: Timber beam bracing
DaveAtkins
DaveAtkins
