OFFSET SURFACES
OFFSET SURFACES
is it possible to simply offset an entie surface in pro engineer wildfire 2.0
RE: OFFSET SURFACES
RE: OFFSET SURFACES
mike
RE: OFFSET SURFACES
RE: OFFSET SURFACES
When you pick the surface, click until it highlights in pink, then you should be able to offset it.
