Rockwell icons
Rockwell icons
Rockwell icons
I would like to include in my Panelview Plus application a page of connected nodes on a network, such as Slc and Devicenet nodes.
I would like to use the icons that are shown in Rslinx or Rsnetworx,
Does anyone know of how to extract these icons in bmp format, so they can be imported into an image format for Panelview display.
Cheers
RE: Rockwell icons
you could probably get the icons from the original installation CD's.  They usually have an icon file in the CD root directory.
RE: Rockwell icons
I've done this before.
What you can do is this. Make a search in your computer for files with 'ico' (Icon) extension.
You cannot use this file directly.
When you find all, select the one you prefer, then open with 'Paint.exe'
Then "select all' and use as a bitmap.
paste, and that's it!
Hope it is what you need
Freddy Guedez
Innovative Refrigeration Systems
www.ammoniarefrigeration.net
www.r717.net
RE: Rockwell icons
Sorry, I wanted to correct my profile, so this is
just a corrected version of previous post.
Freddy Guedez
Shenandoah Engineering Services
www.shenengr.com
RE: Rockwell icons
Thanks for the info guys,
Found all i need
Fornhamspark
