vgroove on a curved surface
One other question, if anyone can help.
I am making a round part that is tapered.  I need to make
8 v grooves along the tapered surface about 3/8 inch deep.  The vgrooves are along the axial axis.  Thanks in advance.
RE: vgroove on a curved surface
Check out Revolved Cut in the help files.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
romanp,
One good way to learn SolidWorks, create a test parts and assemblies and drawings. Go thru each one using all icons to see what they do....in addition to the tutorials CBL suggested above.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I also suggest getting some training which will build a good solid foundation.  If you don't establish a good solid foundation you can expect nothing but problems and issues with your models.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
Ooops! ... sorry just re-read you question ... "along the axial axis".
You need to create a plane perpendicular to the tapered edge,  sketch the v-groove onto that plane, then do a Cut-extrude.
[sigh] ... & then pattern around the taper.
