What does "atan2(value1, value2)" mean???
I'm trying to apply a function, in MS Excel, posted on the internet from mathcad.
Somewhere it says that "value=atan2(value1, value2)"
I don't get it...
It can't mean atan(atan(value1, value))
What's with the "(value1, value2)"??? How do I calculate that???
Any help is highly appreciated
RE: What does "atan2(value1, value2)" mean???
Standard atan function take argument of x/y
atan2 takes arguments x and y.
TTFN
Mathcad atan2(x,y) Returns the angle (in radians) from the x-axis to a line containing the origin (0,0) and the point (x,y). The value returned is always between -p and p, including p.
Excel: ATAN2(x_num,y_num) Returns the arctangent, or inverse tangent, of the specified x- and y-coordinates. The arctangent is the angle from the x-axis to a line containing the origin (0, 0) and a point with coordinates (x_num, y_num). The angle is given in radians between -pi and pi, excluding -pi.
Syntax: ATAN2(x_num,y_num)
               X_num    is the x-coordinate of the point.
               Y_num    is the y-coordinate of the point.
Remarks:
             o  A positive result represents a counterclockwise angle from the x-axis; a negative result represents a clockwise angle.
             o  ATAN2(a,b) equals ATAN(b/a), except that a can equal 0 in ATAN2.
             o  If both x_num and y_num are 0, ATAN2 returns the #DIV/0! error value.  To express the arctangent in degrees, multiply the result by 180/PI( ) or use the DEGREES function.
I think the emphasis is slightly wrong in the above, judging by the results in other languages.
Typically a=atan(x) returns a in just two quadrants (typically -pi/2 to pi/2). atan2(x,y) typically examines the sign of each argument and returns a in any of 4 quadrants.
Try atan2(-1,1) atan2(1,-1) atan2(1,1) and atan2 (-1,-1) to see what is going on.
Cheers
Greg Locock
Thanks everyone
Now I only need to know what csc() means ...
Regarding atan2, I found this function that will work in visual basic:
Public Function Atan2(ByVal y As Double, ByVal x As Double) _
    As Double
  Dim theta As Double
  If (Abs(x) < 0.0000001) Then
    If (Abs(y) < 0.0000001) Then
      theta = 0#
    ElseIf (y > 0#) Then
      theta = 1.5707963267949
    Else
      theta = -1.5707963267949
    End If
  Else
    theta = Atn(y / x)
    If (x < 0) Then
      If (y >= 0#) Then
        theta = 3.14159265358979 + theta
      Else
        theta = theta - 3.14159265358979
      End If
    End If
  End If
  Atan2 = theta
End Function
Found it at www.answers.com
csc = cosecant
csc(x) = 1/sin(x)
SteffDK
It is recommended before you ask any question to invest searching yourself for answer. The value of this is that you may became self-sufficient and exercise a basic skill for searching.
One way to accomplish that is using the software help menu or hit the key [F1].Other way is using the software manual or searching the internet.
Good luck
