CONVERTING SOLID WORKS TO SOLID EDGE
Is there any way to convert files between Solid Works and Solid edge?  Not just having a solid view of the part, but being able to change geometry etc.?
So far it seems that although both programs use the same  kernel, there is no a straight forward method, if possible at all.
RE: CONVERTING SOLID WORKS TO SOLID EDGE
No you will have to Parasolid them out. In SW you can use Feature works to get back to a Feature tree that you can edit.
There are very few if any at all CAD systems that are full compatiable with each other.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
