Macro to rename ass, sub-ass, parts, drawings...
Hello all,
I frequently have a new project number that is similar or identical to a previous project number for an assembly and all of its parts and drawings.
I was wondering if there is a way in which I can quickly rename a copy of the old files instead of using "save as" for each assembly, sub-assembly, part and their drawing files.
Much appreciated,
Andrew
RE: Macro to rename ass, sub-ass, parts, drawings...
When you "Save As", you can rename all of the files that belong to a single assembly.  In the "Save to" menu, click the "References" button.  There you can "save As" all of the loaded reference files.  You can specify new directories, and do find/replace for parts of file names.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Thanks for your tip it helps but I cant seem to be able to reference the Drawing files of the parts in the assembly.
Anyway you know of to do that?
No easy way.  One possibility (if your project isn't too large) is to have all of the drawing files open the same time you save assemblies and parts.  Then, when drawing files undergo "Save As", they are referring to the newly-renamed parts.
...or use SW Explorer
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
