V$ model into V5R15
V$ model into V5R15
V$ model into V5R15
What is the best way to bring in a .model file to V5R15?  If it is 2D wireframe, can it be shown on a CATDrawing file?    V5R15 SP0
RE: V$ model into V5R15
Sorry thats V4 not V$
You just need to read it in.  You will get all of the draft and model information at the top, in a tabbed format.
From there, you can copy and paste whatever info you want, into a new V5 file.
Check out CATBlog!
So what does MIgrate V4to5 do?  What is its function?
It's a batch submission utility.
I've never used it for V4 to V5, but my guess is that you still have to "touch" the file.
Opening a V4 file in V5, only shows you what the geometry looks like.  You can't do anything with it until you place it into a V5 file, and save it as such.
Check out CATBlog!
a couple comments:
You can only read (or migrate) V4 space geometry to V5.
V4 drawings must be converted to .dwg before you can read them in V5.
Make sure you turn on the PROJECT 3D WIREFRAME option in Tools + Options + Drafting before you make a CATDrawing from your V5 CATPart
jackk - that't not exactly true...
V4 drawings come in as 3D in V5, when reading a .model file.    You don't have to turn them to .dwg. (I get these all the time - they are tabbed as a "draft" upon read)  You can actually paste them, and copy the whole thing as one view.
Check out CATBlog!
I stand corrected - thanks Matt
NO NO NO NO NO NO.
V4 Models can be read, manipulated, and used in V5 without migrating them!
V4 3-D Models can be used in V5 CATProducts.
V4 3-D Models can be used in V5 CATDrawings.
V4 Drawings can be viewed in V5, although you may not like the way they look.
The only reason to migrate a V4 model to V5 is if you need to change something inside of it.
That being said, you will not be able to manipulate the parts inside of the model individually.  So unless you modelled your V4 stuff mono-detail (i.e. one part per model), you may need to convert the parts to V5 in order to work with them.
The Batch utility works pretty good.  If you have a V4 Model with multiple solids, sets, and details, it will automatically migrate that to a CATProduct with multiple CATParts.  If there is a drawing, it will also migrate that.  If your drawing used AUXVIEW2, it will automatically link the new CATDrawing to the new CATProduct.  If you used transparent views, they will be migrated to Isolated Views in your CATDrawing with no link to the 3-D.
Am I doing something dreadfully wrong?
1) I don't use Products very often, so I'm ignorant and admit it.
2) My .model drawings come in on a 3D plane
3) V4 models, for me, get pasted into a .CATPart, so that I can modify them. (I assumed that was the point)
That being said, I have to ask - maybe this is an ingorant question - but in what scenario would someone want to use a non-migrated V4 model with 2D wireframe, to make a V5 drawing?
It's true that much of our dialog may have been based on assumption, but I may have something to learn in this thread.
Check out CATBlog!
The basis of this question was the fact I have received 2d wireframe part data.  Not realiozing that it is possible to make 3d edges from that 2d wireframe, i needed to show the part data in what My company is giving a concept of.  No I would not want to use 2d wireframe.  But I have to build a rack to hold the part data in.  In the case of not being able to get 3d part data, i was looking for a way to get 2d wireframe items to show up on a CATDrawing.  I am sorry if I should have explained a little better.  Thanks to all of you for your help
That been said, I am still not sure exactly how to take the 2d wireframe and add edges to it.  If anyone could help, it would be greatly appreciated.  Thanks again.
1) Do you work with assemblies? Or just detail parts?  If you are working assemblies where you have multiple bodies in a single CATPart, then you really need to make the switch to mono-detail.  A significant amount of V5's power is in the Assembly workbench.
2) Are you doing a Copy/Paste to a new .CATDrawing?  Or using the Batch Migration tool? I would check your options, as the V4 DRAW should come into a CATDrawing.
3) That's the simplest method of migration.
The scenario we have is when working with a large number of released document that were released in V4.  We are doing a new drawing of an assembly that contains some of those parts, but with no modifications other than location.  It also includes new parts.  So we have a new V5 Drawing that is linked to old V4 Models and new V5 Parts.
Also note: If you are working mono-detail and using .CATProducts, Aircraft Coordinates no longer matter!!!! I know that is heresy to an old v4 user, but it's really quite true.  A detail part can exist at zero, and be placed into it's ships coordinates when you build the assembly.
(1) I am working with assemblies of single catparts that have a single body.
(2) The process I go about making a catdrawing is,  I create a new CATdrawing/I use View wizard and insert views based from a catproduct(in which the 2d wireframe has been inserted into, sometimes up to 30 times/6 is the least).  I don't always need to show all pieces, though. The parts that are 30 don't consist of too much either.  I don't always have to show all 30 parts.  I then add a few dimensions, add the titleblock requested.  Please ellaborate on the batch migration tool.  I am not fimiliar with that term.
What is mono-detail?
The Batch Migration Tool is under TOOLS, UTILITIES, V4TOV5MIGRATION.
By Mono-detail, I mean 1 part, one model.  The old v4 methodology allowed the user to have multiple parts in each model.
As for adding edges to the wireframe, I don't think you need to.  Both wireframe and surfaces should appear in the drawing when you turn those options on.  Look under the properties of the view, and you should see an option for showing 3D wireframe.  There is also an option for "can be hidden" that allows some limited Hidden Line Removal.
