Metric Screw Thread Callout
Hi All, new memeber.
Have a question on how to dimension a screw thread. It's metric, 16mm with a pitch of 1.0mm. Need to tap a hole with this type of thread. Am using the ANSI Y14.5M-1994.
All I can find in my references are a minumum nominal size, threads per inch, thread form and thread class. I'm used to calling out fractional threads as .250-20 UNC-2B. What is the format for calling out metric threads with these parameters?
Thanks in advance.
Thanks in advance.
RE: Metric Screw Thread Callout
Look in the Machinery Handbook for more info.
Do a google search to find more info.
Also...FYI, it's ASME Y14.5M-1994, not ANSI. And it doesn't have thread info.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Go to Machinery's Handbook for this information. If you don't have one you should consider getting one.
TYou could try the Maryland Metrics webpage. They have good data there. I trust you can find their website.
Tunalover
I have a bright and shiny brand new machinists handbook sitting on the floor of my office. I always forget about that thing because I try to use Y14.5 exclusively. Machinist's handbook is a reference only thing for me.
Thanks again. Looks like a pretty informative forum. I'll be checking back often.
