v5 offline Nodelock extract: driver not running error
XP service pack 1. R12sp6, r14, r15 installed
try to extract an offline license. I get the error "License not added, Driver not running
RE: v5 offline Nodelock extract: driver not running error
Have you ever successfully used a license on this machine before, or is this a first time setup?
Check out CATBlog!
Used online concurrent.. not offline
Do you have LUM installed on the machine for which you will be using the concurrent offline? (evidently Yes, if you've used concurrent online)
If so, is it version 4.6.7?
Check out CATBlog!
had LUM 4.6.8
then uninstalled it. have the i4ls.ini installed.
I can see the licenses but when I select one and click "extract" it gives me the error.
You uninstalled LUM, but have the i4ls.ini installed?
Not sure what you mean there, but you will need to have the LUM installed on BOTH machines, (or on the server and your machine) and a network connection, until you have successfully extracted the license. (which I guess you know)
Check out CATBlog!
The adaptor you are using to access the network containing the lum server and the adaptor the target id is bound to have to be the same otherwise you will have trouble.
Pete
Fixed.
Had to uninstall LUM and reinstall. The LUM was running as a server on the laptop. doesn't work for extraction. reinstalled as client only.. works now.
