ASD Side Resistance for Drilled Shaft Rock Socket
The formula given in Article 4.6.5.3.1 of AASHTO HB-17 (page 85) for ultimate side resistance reads as follows:
Qsr = (pi)*Br*Dr*(0.144*qsr)
Yet the label on the y-axis for Figure 4.6.5.3.1A indicates that qsr is the unit side resistance.
Should the formula read:
Qsr = (pi)*Br*Dr*(144*qsr)
to make the units work out?! Or do they intend to reduce Qsr by a factor of 10 for some reason?!
All responses welcome.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
RE: ASD Side Resistance for Drilled Shaft Rock Socket
Sorry, reduction should be 1000 - not 10.
Jeff
The question was answered in the Foundation Engineering forum. Qsr is defined in kips, therefore 0.144 is correct.
Jeff
www.ttlassoc.com
