DTL file location
DTL file location
I would like to edit my .dtl advanced drawing set up file and have my file come up automatically when I start Proe. What folder do I need to place this file in?
RE: DTL file location
Check this thread thread554-102620 it's from the Pro/e forum.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
A prodetail.dtl file should be on your local harddrive(s) to copy, don't write over the original just incase you need it again. In your config.pro, change or create: drawing_setup_file N:\prodetail.dtl (the file path should be to your local copied & modified prodetail.dtl file).
drawing_setup_file "path to dtl file"
Heckler
