Japanese pressure vessel code (KHK certification)
I am looking for general hydrotest information for Japan's KHK certification for pressure vessels. Specifically, how is the hydrotest pressure defined? Is it a similar test comparable to UG-99 and if so what parameters are used; i.e. 1.3 X MAWP or some other factor? What is the ramp up and hold times? Any experience anyone could share in this area would be greatly appreciated.
TIA
TIA
RE: Japanese pressure vessel code (KHK certification)
If you are with HSB go to their website.
Check:
http://www.khk.or.jp/e_khk.htm
for a start. 1.5 MAWP is typical but there are variations. If you do not get design review you may be out of luck.
Thanks again
Urbanite
