Edge Distance in Grouted CMU
Load capacities for adhesive anchors in Hilti and Powers Catalogs vary depending on the "Edge distance" or "distance to free edge".
Does the edge distance refer to the distance from the anchor to the mortar joint in an individual block or the distance from the anchor to the edge of the block wall?
If all the cores are grouted solid, does it make any difference in load capacity, if the anchor is installed in a mortar joint and not in the center of the block?
RE: Edge Distance in Grouted CMU
If all the cores are grouted solid it does not make any difference if the anchor is placed in the mortar joint.
Thanks again!
