SOCKOLET 12"-8"X 1 1/2" 3000+ FOR PIPE 1 1/2" SCHED. 160
HOW CAN I DETERMINE IF A INSTALLED SOCKOLET 12"-8" X 1 1/2" 3000 POUNDS IT IS ALLOWABLE FOR PIPE 1 1/2" SCHED. 160, ALTHOUGH NO COMPLY WITH THE CORRELATION OF FITTINGS CLASS WITH SCHEDULE NUMBER OR WALL DESIGNATION OF PIPE, FROM ASME B16.11?
THE DESIGN PRESSURE IS 1280 PSI
I WOULD APPRECIATE YOUR SUGGESTIONS
RE: SOCKOLET 12"-8"X 1 1/2" 3000+ FOR PIPE 1 1/2" SCHED. 160
I hope that this helps you out.
