Material, relationship between "E" and yield strength
I am working on a plastics problem where there are a variety of formulations with a varitety of strength properties. I can see that when the material Modulus of Elasticity, E increases the yield strength does as well, and vice versa. Is there a real realationship here? If I get a range of E values and a range of yield values is it correct to assume that there is a linear relationship between the max and min values of each.
EngForm78
EngForm78
RE: Material, relationship between "E" and yield strength
do you mean the yield stress?
If yes, as far as I know, there is no such relationship.
Alex
good57morning@netzero.com
i think engform78 was asking is the a relationship between yield stress and E; rather than stress = E*strain.
as mihaiupb notes, there isn't. different "flavours" of Al (2024, 7075) have the same E, but different yields.
It is just a coincidence and there is no linear relationship. For a lot of metals, the stronger they are, the stiffer they are.
A simple exception is Titanium which is not very stiff compared to steel but is stronger than many steels. Titanium is not, however stronger than the strongest steels.
I'm sure if you narrow the material down sufficiently, you can get some sort of relationship. For example, I think ACI has a formula for E vs. fc' for concrete. If you were just varying one component of the plastic, you could probably do something similar.
I seem to recall from long ago that E with plastics was also time dependent, which would further complicate matters.
