Supplier for polyurethane viscoelastic system
I am looking for some companies who can supply the raw material for making viscoelastic foam. My client has approached several chemical suppliers such as Bayer and other, but they would also like to see the possibility of getting the system from other manufacturer preferably based in America and Europe.
DA
DA
RE: Supplier for polyurethane viscoelastic system
Also the end use is very important.
The environmant the foam is exposed to is important. The answer to the questions will determine the proper foam to choos and which manufacturer to pick.
