Pavement density
Pavement density
I have some 'rule of thumb' pavemnt density number (about 147 lb/cu ft for top mix, and about 120 lb/cu ft for a base mix)but need some published source to back these up. All the DOT guides give great information on what to put in the mix, asphalt percentages, denssites 9as a percentage of the marshall number) and so forth, but need one that lists an acceptable range for pavemnt. It is for a cost estimate (for several actially) in the N Jersey area. Thank you in advance.
RE: Pavement density
http:/
Check out Chp. 4 sections on computations.
