Replace part/assy in dwg
I don't have 2006 yet. Do you guys know if you can replace an assembly with another assembly in a dwg with SW 06?
I have a complicated dwg with a big assy. There is a new assy that is 90% like the other. I would like to replace the old with the new and rename the dwg for the new.
thanks
thanks
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: Replace part/assy in dwg
Jason
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Select File/Open
In the open dialogue, select and highlight the drawing, then select the "references" button.
Double click the assy path shown and browse for the new assy.
Ok that and the "Ok" to open the drawing.
In Solidworks Explorer:
Open drawing file.
In the tree, right click the assembly and select replace.
Browse for new assy
Apply
Jason
1) open the Drawing
2) select Edit\Replace
3) Highlight Assembly
4) Select "Browse" and browse for new assembly
5) You can do a "find where used" if the assembly is used elsewhere, recommended if you do this to parts.
6) Select "apply"
If you have anything in the Find where used box there they will turn blue, informing you they have been updated.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
see thread 559-122252
"Drawing reference: Was assembly, is Part"
This should be in the FAQ because it has been asked a few times, but in different ways.
Flores
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Swx Explorer is the best way to visually see what's going on and provides more options for maintaining references, where-used, etc.
Now if Solidworks would just replace the "References" button in the Open/Save dialogue with a revamped Explorer interface. Time for an enhancement request.
Jason
Gildashard, the open/file references worked! perfect!
thank you
Chris
FAQ559-1100
FAQ559-716
The SolidWorks Explorer is a file management tool designed to help you perform such tasks as renaming, replacing, and copying SolidWorks files. You can show a document’s references, search for documents using a variety of criteria, and list all the places where a document is used. Renamed files are still available to those documents that reference them.
NOTE: The SolidWorks Explorer is not a PDM (Product Data Management) tool; however, it does perform many useful tasks and simplifies many file management processes.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
I agree with you guys 100%.
I use SW Explorer all the time for various issues.
But the only thing it won't do for me is replace a part/assy in a dwg. Time for another Enh Req.
thank you for your help
Chris
FAQ559-1100
FAQ559-716
I use SW Explorer all the time for renaming files, changing properties, etc. because of the "find where used" feature. I just haven't used it for repacing Asm. A with Asm. B on a drawing.
As for replacing a part or sub-assembly in an assembly within SW, I right-click what I want to replace, and pick "replace components".
Cheers
Flores
I've only had to do this once. I think what I did was save a copy of the drawing. Then replaced the copy's assy with the second assy. The cut and pasted the views in the copied drawing file back into the original. Now the drawing is pointing to two assembly files.
Jason
It's just the user bud (no offence), no need for an ER. I just made an avi file for you to look at and show you how it's done.
I sent it to your yahoo address from your home website.
Check it out.
Best Regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
"I do it in Solidworks, not SW Explorer.
'Drawing reference: Was assembly, is Part'"
That thread that you mentioned was a bit of a special case that I believe is still not possible; Changing the reference of a drawing from a assembly to a part.
Anybody with 06 give this a try?
I tried that per your video, but for some reason doesn't work for me...never has. It works well for replacing a component in a assembly, but not a dwg.
I may have to reload SW Explorer, maybe it will fix it.
thanks again.
Chris
FAQ559-1100
FAQ559-716
The correct way is BEFORE OPENING THE DRAWING, in the Open dialog box, pick the drawing (not open), and the lower right-hand side hit the "References" button. From there is where you can double-click a specific page and change the reference.
Yours was a simple assembly with sheet metal + pem nuts. Not only have I replaced the assembly with just the sheetmtal, but I have changed square tubing that had Riv-nuts to just the part with no Riv-nuts.
Flores
What version of SW are you using. As per the former thread (thread559-122252), I did exactly as you state, clicking references BEFORE OPENING THE DRAWING and I select the part that I want to replace the assembly with. It fills in the path, the way it should, but when I select OK, I get an error message. I am using SW2004 with the latest service pack.
Does this work with a newer version? I haven't tried with 2005 at home.
I have done the references replace game many times, but it only works part to part or assembly to assembly, not part to assembly. This is in the context of opening a drawing of course.
I am using SW 2005 SP 4.0. Don't know why it isn't working for you, because I have done this on several occasions. Typically it is when a client wants to save money and wants a thru-hole and will use nuts and bolts instead of paying for the pem nuts or riv-nuts as well as the labor to install them.
Flores
I suggest doing a insert part for adding something like pem nuts. Otherwise you will have to rebuild the drawing from scratch.
Oh, and please submit an enhancement request for this.
Jason
-Shaggy
But just like the original thread, I am getting mixed opinions of this.
smcadman says he can do it with 05. I will try it tonight, but if anybody else wants to try it and post the result, I would appreciate it.
I did submit an enhancement request for this after the last thread concluded that it was not possible.
Chris
FAQ559-1100
FAQ559-716
ctopher,
I see from your signature, you are using 05, sp3.1. Is it possible this feature was added in 05, sp4.0?
Chris
FAQ559-1100
FAQ559-716
Jason
Jason
Last night I tried the process that I have tried numerous times already, this time however on 2005 sp4.0. I got the same result, it did not work.
I ask anyone who would like to verify this by quickly repeating this task (takes about 5 min).
1. create two parts, part1 and part2
2. create an assembly with part1 and part2
3. create a drawing of the assembly
4. close all files
5. begin the process to open the drawing, however prior to clicking open, click on references in the lower right corner.
6. You will see that the drawing is referencing the assembly.
7. Double-click on the assembly path and browse to part1
8. You will see that part1 has replaced the assembly in the reference (all good to this point)
9. Click OK and you WILL receive an error message about not being able to switch the file type.
smcadman,
If you are able to do this without the error, you are magic.
I have never seen that work for me or anyone here at our company. Only replacing a part with a part or assy with an assy.
Chris
FAQ559-1100
FAQ559-716
-Shaggy
Tally
Works Doesn't Work
0 2
Just as Jason stated, you can replace a part with another part on a drawing on a drawing. You can also replace an assembly with another assembly on a drawing. You can do that any version of Solidworks.
But we should not think about replacing a part with an assembly, or replacing an assembly with a part on a drawing. This does make sense, and it is wrong logically. Also, I do not see any reason of doing so.
Alex
Read the previous thread thread559-122252
Same thing happened with SW Explorer, which does not give the option to browse for an assy if you want to replace a part with an assy...within an assy.
Chris
FAQ559-1100
FAQ559-716
How exactly did you make it work and what version are you using?
Chris
FAQ559-1100
FAQ559-716
I just read your original post copied below:
I have an assembly model that consists of two components. A drawing was created of this assembly. Later one of these components was found to no longer be needed. I still have a drawing of the assembly that now contains only the one part.
The drawing is of a sheet metal component that has some PEM hardware inserted. The assembly is an "inseparable assembly" and we do a drawing of the assembly file only. No drawing is ever created of the part. In this redesign, the pems are no longer be needed, we can do away with the assembly file.
Ideally I would like to replace the assembly reference within the drawing with the part model. I would then delete the assembly file. I don't want to recreate the drawing from scratch and can't seem to trick SW into recognizing the part file.
Anyone ever run into this situation?
I don't think your company handles engineering drawing document properly. According to what you described, you made the following changes:
1) You removed a part ("part A") from your assembly;
2) You later removed all of your PEM hardware from your assembly;
3) Now your assembly contains only one part ("part B");
4) You decided to obsolete your assembly;
5) You need to create new drawing for your part ("part B")
Please be aware that even though an view of a part looks identical to an view of an assembly with the same single part, behind the screen there are different definitions. Each entity (point, line, circle or arc, etc) has its unique ID. So, this will not work, should not work. All your annotations on your assembly drawing based IDs of assembly views. In no way, will they reconnect to IDs on the views of the same part. This is just how database programing works.
Additionally, you should not make a part based on an assembly drawing documents unless the part has some or all assembly features in it.
Alex
All the changes were done in pre-release stage of design. The desire to use through bolted fasteners rather than pems was what drove the change.
Your description of my process is not quite accurate. 1 and 2 are the same. We had a sheet metal piece with some pems installed, we decided we no longer needed the pems. We had a drawing of the sheetmetal piece with pems installed. This drawing is the manufacturing print for the sheet metal piece with pems installed. We do not do a separate drawing for the sheet metal and an assembly drawing indicating which holes get pems. This is redundant for our purposes because we outsource all of our sheet metal fabrication. We simply tell the metal shop that we want a part with such and such dimensions with pems here and there. I am not going to tell a fab shop what size hole to use for a standoff, I just want a standoff.
Concerning number 4, we did not obsolete our "assembly", we simply removed the pems from a "part". Everything else is still valid.
I agree, unfortunately, that at the present time the only way to correct the issue is to create a new drawing of part b only. However it seemed that SW should allow the reference change.
Your explanation of the of the entity IDs may very well be valid and the reason why this seemingly simple request is impossible. I thank you for that.
