Starpoint Isolated from earth.
I'm loking for more information on the next two item's.
About a IT-net (Starpoint Isolated from earth.) and a NT-net (Starpoint is earthed.)
(European: 240 Volt)
About the regulations.
Can we say that a IT-net is a Alternating supply, singlephase with earth (3-wire system) or is it could different.
RE: Starpoint Isolated from earth.
Can you please rephrase your question?
In the meantime check:
www.schneider-electric.com/ cahier_technique/en/pdf/ect172.pdf
(copy and paste whole address)
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
About an IT-net (Starpoint Isolated from earth.) and a NT-net (Starpoint is earthed.)
The problem is that we have sold a machine. Inside the specifications, there is a note about the electrical supply. "Alternating supply, single-phase with earth (3-wire system)"
Thinking that this is the definition of a NT-net.
The customer has now an IT-net and is saying that his powersupply is the same as our definition inside the specifications.
