SW 06 and macros
SW 06 and macros
SW 06 and macros
Is any one having problems with using old macros with SW 06?  We have a macro that saves a drawing as a DXF 1:1 When you run the macro SW opens a save as dialog box wants to save the part and then saves the drawing as a DXF after you save the part. The macro has the corect references. Any sugestions?
thanks in advance.
Grant
Applications Engineer
SW2006 SP 0
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1100
RE: SW 06 and macros
Grant,
When I have problems like yours, what I would do in re-record the macro. Of course if it is an easy one.
Bradley
Some of our macros are producing error messages in 2006.
Rob Rodriguez CSWP
www.robrodriguez.com
SW 2005 SP4.0/SW 2006 EV
HAve you checked to make sure the API code hasn't changed in SW06. That would seem to me like the likely culprit.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I don't know about 2006, but I had a macro for 2005 that my var made some additions to and when I got it back it would error out.  The fix was to start a new macro and simply copy and paste the code in its entirety into the new macro and save it to a new name.  It then worked fine....
Also, is that a macro that you can share?
Rory
I did not write the macro so I don't think I can share it but if I can give some sort of guide line I would be more than willing to do so. I'll look into it.
I think it's something with the API as Scott stated.  Still investigating that.
Re-recording won't work (I think) because it's some what complex as far as to where it saves it.
Grant
SW2006 SP 0
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
