Nickel plate finishes
I have some parts that have been nickel plated. There is an obvious difference in the shine of the parts from different batches. Some have a bright glossy nickel finish and some from another batch have a duller, almost matte-like finish. What kind of spec can I put on a drawing to control the finish of the nickel plated parts?
TheWeirdo
TheWeirdo
RE: Nickel plate finishes
http://www.welding-advisers.com/
TTFN
Does it contain P? How much?
You need to narrow things down a bit.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
