Calculating the second moment of area
Basically i am trying to calculate the load required to deflect the finger of a collet. Its a pipe with slots milled along its length and these fingers will deflect when the collet is inserted into another pipe. So the finger is sort of circular in cross-section. I'm finding it hard to calculate the second moment of area for it and would appreciate any help. i seem to have forgotten a lot of the beam theory that i once knew. i have found the centroid of the shape, do the neutral axes run through the centroid? Cheers
Jonny
Jonny
RE: Calculating the second moment of area
