IMPORT OF BLOCK FROM AUTOCAD 2005
I HAVE A TITLE BLOCK IN AUTOCAD WHICH I WOULD LIKE TO HAVE IN EXCEL (FOR PRESENTATION PURPOSES) BUT NOT ACTIVE - A PICTURE OF IT I GUESS.
I HAVE TRIED SPECIAL PASTING BUT IT IS EITHER TO SMALL OR THE QUALITY IS LOST. ANY IDEAS. THANKS
RE: IMPORT OF BLOCK FROM AUTOCAD 2005
In Excel choose insert->picture->from file then find your picture.
Dik
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
as johnwm said, in autocad, under "File" click "export" chose your item(s) and save as wmf file
in your excel file insert as picture from file and crop and resize
resize from corners so the original aspect ratio is maintained
I hope this helps
Good luck
Best regards,
Andrei
