microsoft access: sub forms
I have a form with a subform in it. And I try to put a command button in it, but when I put the form in form view, all that shows up is the query in the subform. How do I get the command button in the subform?
RE: microsoft access: sub forms
In design view, directly load the sub-form.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
