Eccentric Clamping Force - Formula
Sirs:
In McGraw-Hill’s Machining & Metalworking Handbook I found the following formula for the clamping force by a round eccentric:
P = Q l . l/[tan(?+?1) +tan(?2)]r
Where:
•    r: Distance from pivot point to contact point of the eccentric and the machined part surface
•    ?: Rotation angle of the eccentric at clamping
•    tan(?1): Friction coefficient at the camping point
•    tan(?2): Friction coefficient at the pivot axle.
•    l: Handle length.
•    Q: Force applied to the handle.
•    P: Clamping force
As I have some doubts that the formula is correctly typed (in the book), can someone confirm if it is right? or, better,  inform  where can I find its  deduction?
Thank you,
Julio
