Hall Effect Latches
Hall Effect Latches
Hall Effect Latches
I am attempting to implement a Hall Effect latch to replace a simple mechanical switch; I have been disheartened to discover that these devices seem to have a current draw in the order of 3 microamps.  Is it possible to generate the same effect (even if the sensor is dramatically less sensitive) with a current draw in the order of 50 uA?
Thanks.
RE: Hall Effect Latches
Is the 50uA == 50 microA ? If so there is some confusion.
The simplest way to reduce the power is  to use it in sampled mode. ( e.g. 100 times per sec. for a few microS )
If you want to replace a mech. switch, did you consider
a -- perhaps  mercury wetted  -- reed switch ?  It is hermetically closed, lasts a LONG time and simple and cheap... -- and fast enough to replace a mech. switch.
<nbucska@pcperipherals.com>
