Linetype in Layout Space
I'm building a pipeline map that covers about 50 square miles. I'm using linetypes to indicate different pipe sizes. In the "model" layout I put "linetype scale" to "50" and the dashed lines show up as dashes.
The problem is that when I go to an output layout, Autocad doesn't seem to honor the scale and all lines show up as solid.
I went into "model space" on the output layer and zoomed the map in to less than 1 square mile and the lines were still solid.
Anyone have any ideas?
David
David
RE: Linetype in Layout Space
Hope this helps,
John
(only 0 or 1 value)
Flores
Thanks all.
David
