Seismic analysis
Seismic analysis
Seismic analysis
Hi All
I have performed a seismic ground response analysis in ansys. I wonder if you guys know any way to make a fourier transform for output acceleration time history obtained in analysis?
RE: Seismic analysis
What are you using as your post processor?
Cheers
Greg Locock
Do you want to obtain the fourier transform of your acceleration time history/response? You can do this in ANSYS using APDL. See the *MFOURI command in the help file. Also search the archives here on details how to do this using APDL. Other than that, if you have access to Mathcad or similar, it is much easier to output the raw time history data and use these.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
