What is 316LNG
What is 316LNG
I am reviewing some technical specifications which call out for 316LNG material.
As far as I know, NG stands for 'Nuclear Grade'.
I couldn't find this acronym in ASME sections II material specifications.
A colleague of mine told me that, if special requirements for 316LNG exist, these should be given by the Technical Spec. and not by any ASME Code spec.
Which are the requirements (chemical composition, mech. properties, ...) for 316LNG SS, if any?
Are they different from those of 316L SS?
RE: What is 316LNG
Which is a subject of its own.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
RE: What is 316LNG
Ed, your comment re: cobalt is mentioned over there.
rmw
