Controlling four Linak actuators.......
The units are Linak medical bed actuators, run on 12 or 28V, usually run by a hand-controller and usually without installed potentiometers. What I would like to do is operate four of these units with some sort of controller/power board and a standard PC control-stick so that they mimic the control-sticks' inputs as accurately as they can operate under normal operating conditions to basically computer-mix the actuators(stick back, all actuators extend, stick forward, all retract, any position in between, all actuators assume their proper position to reflect the stick's position.) If if this can be done, please let me know.
Thanks so much!!!!
Thanks so much!!!!
RE: Controlling four Linak actuators.......
One way of doing it would be to use "sensor bearings" in the units and use their output signals to keep track of linear motion. The math from actuator position to target position can be complicated, but if the four Linaks are not dependent of each other (each Linak does its own thing) then the math is simple.
You could also, depending on the resolution you need, put little sensors in the actuators (I think that Linak has versions with sensors built-in) and count output from them in the same way as said above.
A few questions that will have an impact on what solution you should chose: Is this a low or high volume application? Does it need to be non-volatile (be able to resume operation without sync operation after a power outage)?. Is it a cost sensitive application? Is the environment tough or hostile - or is it a normal in-door climat?
Gunnar Englund
www.gke.org
One type of linear actuator which isn't particularly accurate though doesn't suffer from cumulative error is a voice coil type permanent magnet actuator that is spring loaded. The voice coil actuator is basically the same type as used in a loudspeaker (hence the name). Because it is spring loaded, the position is a function of the current hence approximate positioning can be achieved BUT the actuator must be energized continuously. For a given holding force requirement it is relatively large and expensive (in terms of both first cost and energy use), though it can be fast. One application is active valve control in a piston engine.
Better to get a position sensor I would say.
I'll go back to the Linak site, and see what they recommend for accurate feedback control...mayhaps they have units with such controls already installed. The unit I have for testing does not. I'll report back with the info they give me to bounce it off of you folks.
Here's their description of an optical encoder that can be rigged for the actuators:
"The optical encoder is used for positioning and servo control of an actuator."
As opposed to their description of the potentiometer they offer:
"The potentiometer is used where the absolute position of the actuator is needed."
So, which do you folks think would work best? They also offer a controller board which can work two actuators at once......is it possible to link these actuators by two of these controller boards? If it's possible, I can get the specifics, and post them here.
As you mentioned the "bed" control pendants, they usually run one axis at a time so the power supply can be capable of only running one axis at a time. Being able to run multi axi will require a hefty supply. (less cheap)
Can you elaborate on "hefty supply"? Are we talking power, physical size, both?
Optical encoders may be used where there is high speed motion. They generally have very high accuracy as well.
Gunnar Englund
www.gke.org
I have used Linak actuators with integral potentiometers in a valve actuation application. The coupling was via a Bowden cable as they couldn't be located next to the valve; no problems to report. It's probably better to buy the ready assembled item rather than strip down the actuator and fit sensor bearings.
OK...I'll get the Linak units with the installed pots, but now, this power supply issue.........LOL!
I'm thinking one power supply for each actuator mounted closely to each unit would be best, but.......what is the overall controller to which the stick inputs to? Do I run a standard PC board with a subroutine that simply maps the stick's patterning? Should I switch over to a computer forum to figure out the controller-to-power supplies-to-actuator rigging?! LOL! Thanks all, especially for being patient with an obvious newb!
If you are talking easy, clean, and painless, one PS/actuator IS!
Make your choice.
You should look into a regular PC joystick to "output" card. This will allow a cheap replacable joystick and different input devices like game controllers etc.
I'll take the more expensive, but easier route of one power supply per. The electronics hooking up to the actual power supply still boggles me, though. Ah well, a searching and a studyin' I go!
It is not automatically so that a single power supply has disadvantages over the one PS/actuator approach. It all depends and it depends on a lot of factors.
Regarding the positioning accuracy, it is sometimes possible to have a +/- 2 or 3 percent accuracy (=repeatability when moving from fully retracted position to setpoint) without position sensor. The trick is to measure motor EMF (voltage induced in armature winding). That can be done rather cheaply by measuring load current and compensate for it (well, there are a few more things to it than that). It will always be cheaper to do that sort of control using a central (common to all actuators) control unit than having the intelligence spread out over four different units.
I would recommend One PSU and One Control Unit. Definitely more economic and also much easier if you need to have the different actuators communicate or interlock.
Gunnar Englund
www.gke.org
Here's the basic specs on the Linak actuators:
Max. thrust: 750 N
Max. Speed: 50 mm/s
12V or 28VDC
I only need these units to have a maximum 'throw' of two inches fully retracted to fully extended.
Does this info help, or do I need to find out more? Thanks!
What are you using this for?
controlling panel movement.
37.5 Watts
Times 3 = 112.5 Watts
Pretty small potatoes. Use three 100W switchers. Or three 50W unregulated supplies.
On the other hand, it is not plausible that the actuators will be delivering full power all of the time. It is not even probable that they have to deliver full power at any time.
What forces do you need to move the panels? The 750 N is the spec of the actuator, but what force is excerted on the panel? And what does the duty cycle look like? Do you move tem once in a while or do you move them back and forth continuously?
All these considerations go into the design of a system like this.
Gunnar Englund
www.gke.org
This will be a complete design by forum taking 3.5 years and 3,000 posts.
It's a s l o w work in progress.
Scotty beam me out.
FLOL!!! Sorry for the sea of questions from me; I really like your "Scotty" remark! Skogs, the system will have the actuators moving back and forth constantly, but after an initial engagement of full throw and relatively static positioning(approx 450 N), the units will move back and forth only incrementally, and have very little load on them(approx 75 N)for the duration of their duty cycle. The maximum time of duty will be less than 3 hours per unit. THANKS AGAIN ALL!!!
Your 3.5 years and 3000 posts estimate seems to be quite well underpinned. It is not very unlike some design cycles I have lived through even without computers and internet.Postings were then paper letters, meetings and phone calls.
Gunnar Englund
www.gke.org
Naw! I was just expressing my frustration at having important required details dribbled out a little at a time in some misplaced desire for secrecy. As if everything hasn't been done or tried. Everyone thinks they have the next Ipod brewing. (me included)
The OP can't have it both ways. If he wants tight secrecy he shouldn't be here. OR.... He should at least have his specific requirements very clearly defined. Otherwise if he doesn't have the specific requirements or know how to derive them we need a lot more information on what he wants to do so we can cogitate the specific requirements needed in a timely reasonable manner. I mean, is he trying to keep a ball bearing balanced on the platform, or point something, or heat water by sloshing it? Who knows?!? This would completely change possible control strategies.
At this point I feel we are providing free engineering services for a secret product for the OP to develop and sell.
I would rather provide tips.
Gunnar Englund
www.gke.org
Hospital bed actuator motors have an extremely low duty cycle, not much better than a starter motor on a car. I see that the motors are not going to be fully loaded but if they are going to be starting and stopping at full voltage/speed you may have a problem.
It has been a long time since I looked at those actuators but I think the motor would burn in less than a minute of operation. These motors have to start hard to overcome the static friction of the worm.
Barry1961
ITSMOKED, I can appreciate your frustration at my dribbling out info, but it's not because I have a great idea, it's because what I'm trying to do is not S.O.P., so when I tell people what it's really for, I get a very MUTED response, if any response at all! So, PLEASE, forgive me for dribbling, but truth be told, you folks have gotten me farther with your info not knowing what it's for, than 100 posts on other boards, telling folks exactly what I'm doing!!!! BTW, it's not illegal, immoral, illegitimate, somebody else's idea, or a better mouse trap....FLOL!!!! Now, about that duty cycle question, I don't see that as an issue due to the really low loadings after initial actuation at half-travels back and forth for possibly thirty seconds at the most, BUT I'm not the expert here, so please....elaborate. THANKS!
Acme screws often have a very high static coefficient of friction. It is often very hard to move a short distance with a motor/controller that can not produce full torque at a very low rpm. Many DC motor/controllers just reduce the voltage to the stator for low speed with also gives the motor very low torque. If you give the motor enough voltage to “break” the acme screw free it will often over run the target.
So depending on your setup you may end up with an imposed mechanical resolution of a few revolutions of the motor. You can try giving the motor short full voltage pulses but that opens up a new set of problems. It does not sound like you have the budget for even a pseudo servo control.
Barry1961
