Humidifier Using Nitrogen
Hello there,
I am intending to introduce a stream of styrene (C8H8) at 50% relative humidity into a reactor. Nitrogen passing through water will introduce moisture into the gas stream as needed.
Can someone tell me how I can do the relevant calculation for the required Relative Humidity level? For example, say, I have a stream of dry styrene coming in at 50ml/s, how much nitrogen gas do i have to pass through the humidifier to mix with the strene stream to achieve the 50% RH level?
