PRO/E Modeling Help
PRO/E Modeling Help
is there an easy way to make a complex "solid shell" around an existing solid model and then save a copy of the solid shell only. For example, I have a solid model and want to make 3 separate shells all having different thicknesses and ultimately form 3 separate core/shell assemblies to import to abaqus.
Thanks for the help all,
Chris
Chris
RE: PRO/E Modeling Help
If you want solid Shell Features I think I'd look at creating a family table part; each instance having a different thickness value.
If you want volume boundary rep shells look into copying and offsetting.
