difference between uniform pressure and hydrostatic pressure
I am reading abaqus manual, and I don't know what's the difference between the uniform pressure and hydrostatic pressure.  Isn't hydrostatic pressure a uniform pressure?  What's special about it?  Thanks.
RE: difference between uniform pressure and hydrostatic pressure
hydrostatic pressure is from water pressure, it varies with depth
corus
I don't believe that this is the correct place for asking such a basic question. Clearly the original poster is deficient in science and engineering knowledge and .....
(I'll leave it there before I say anymore!)
Thanks for both of you, even for the criticism.  But sometimes if it's something trivial for you, others may have trouble understanding it, not because he/she doesn't have the basic knowledge or is incompetent, but may simply because of being unfamiliar with the terminology.  Regardless, still thank you.
