Harmonic filters
Harmonic filters
I need to know 2 types of harmonic filters which may be used to reduce harmonics in power systems. PLEASE
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Harmonic filters
1.Shunt Filter (Detuned Filter & Tuned Filter)
2.Active Filter...Good but more expensiveness
http://www.schneiderelectric.com.tr/ftp/litterature/publications/ECT183.pdf
Gord
Two of the most common problems resulting from wrong filters in the network might be :burning of the filter and vicinity and / or explosion of high voltage to low voltage power transformers supplying the network.It is crucial (!!!) before you install any solution to inspect and study your network .Being a professional in the field I would recommend first to study the network in depth. One of the other solution for harmonics may also be a transforme isolating the creator of harmonics from the network and so solving the problem in the most economic way.
A.Rash BScEE & PE
a_rash@bigfoot.com
-tuned filter
-high pass filter
2.active filter
Nitipong Pan-klang
Thailand.
