API Table Feature
API Table Feature
API Table Feature
I hope someone can help me.  I am trying to use TablePatternFeatureData and can't seem to get the sintax to work.  I want to use PointArray or LoadPointsFromFile, but neither will work even if a copy the code from the SolidWorks help file.
RE: API Table Feature
You will have to be more specific.  What happens when you run the code?  What error messages do you get?  Post your code so others can look at it.
Regg
Using the example from the HELP file for TablePatternFeatureData I added a couple lines:
    retval = swTableFeatData.SavePointsToFile("C:\Stuff.SLDTAB")
    Debug.Print "retval = " & retval
    swTableFeatData.PointArray = Array(0.37445, 0.0254, 0.37445, 0.15006, 0.37445, 0.27472, 0.37445, 0.39998, 0.22, 0.0254, 0.22, 0.15006, 0.22, 0.27472)
I was using "SavePointsToFile" to get a sample file format and I was experimenting with the PointArray command.
I have sheetmeal part that has a 4-hole pattern in it that I need to repeat 0-7 times for a max total 8 occurances of the pattern.  I can load the array points either from a file (preferred method) or set the array directly.
Any insights would be a appreciated.
I have never used TablePatternFeatureData calls.  I only have SW2004 at home and cannot seem to find the example you refer to.  Is this example in SW2005?  What is it's exact title on the help screens?
You still did not specify what does not work.  Do you get any error messages or does nothing happen when you run the code?
Regg
No errors are reported.  It just doesn't work.  The Debug.Print retuens a flase statement so I know that the SavePointsToFile command isn't working.
The name of the help page is TablePatternFeatureData.
Post more code.  It would be helpful to see how you are setting up various objects such as swApp and TableFeaureData.
Put a "Stop" statement in your code and open the "Locals Window" when the code breaks to see if your objects getting assigned properly.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Sub main()
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.modelDoc
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swFeat                  As SldWorks.Feature
    Dim swTableFeatData         As SldWorks.TablePatternFeatureData
    Dim swRefPt                 As SldWorks.Vertex
    Dim swCoordSys              As SldWorks.Feature 'Object
    Dim vBasePt                 As Variant
    Dim vFace                   As Variant
    Dim vFeat                   As Variant
    Dim vPt                     As Variant
    Dim nPtType                 As Long
    Dim vRefPtParam             As Variant
    Dim bRet                    As Boolean
    Dim i                       As Long
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swSelMgr = swModel.SelectionManager
    Set swFeat = swSelMgr.GetSelectedObject5(1)
    Set swTableFeatData = swFeat.GetDefinition
    ' Roll back to get the reference point
    bRet = swTableFeatData.AccessSelections(swModel, Nothing): Debug.Assert bRet
'    Set swRefPt = swTableFeatData.ReferencePoint
    Set swCoordSys = swTableFeatData.CoordinateSystem
    vBasePt = swTableFeatData.GetBasePoint
    vFace = swTableFeatData.PatternFaceArray
    vFeat = swTableFeatData.PatternFeatureArray
    vPt = swTableFeatData.PointArray
    Debug.Print swFeat.Name
    Debug.Print "  Coord sys            = " & swCoordSys.Name
    Debug.Print "  FaceCount            = " & swTableFeatData.GetPatternFaceCount
    Debug.Print "  FeatureCount         = " & swTableFeatData.GetPatternFeatureCount
    Debug.Print "  PointCount           = " & swTableFeatData.GetPointCount
    Debug.Print "  ReferencePointType   = " & swTableFeatData.GetReferencePointType
    Debug.Print "  BasePt               = (" & vBasePt(0) * 1000# & ", " & vBasePt(1) * 1000# & ", " & vBasePt(2) * 1000# & ") mm"
    Debug.Print "  GeometryPattern      = " & swTableFeatData.GeometryPattern
    Debug.Print "  UseCentroid          = " & swTableFeatData.UseCentroid
    If Not swRefPt Is Nothing Then
        ' Is NULL if centroid used
        vRefPtParam = swRefPt.GetPoint
        Debug.Print "  RefPt                = (" & vRefPtParam(0) * 1000# & ", " & vRefPtParam(1) * 1000# & ", " & vRefPtParam(2) * 1000# & ") mm"
    End If
    ' Roll forward
    swTableFeatData.ReleaseSelectionAccess
End Sub
