input file about RC column under cyclic loading needed
I am using ABAQUS to modelling confined concrete column under axial compression and cyclic lateral loading, but i am new user. Can anyone do me a favor to provide some similar input file or give me some hint on this topic? Thank you very much! Any suggestion are appreciated!
RE: input file about RC column under cyclic loading needed
I suggested that you look at an ABAQUS/Standard Example Manual where you will find a "Dam" problem.  This example would provide some insight of how to model concrete structure in ABAQUS.
Good Luck.
