steering collar on shaft- theory
We're in a raging debate regarding the "best" way to clock a steering collar on a shaft (for a gear assy). The collar slides up and down as the shaft rotates.
The argument being which is better- more small contact points (such as a spline) or simpler geometry such as a flat on a cylinder. Other options include a tang or multiple tangs.
Assume any design we come up with can handle the load so strength is less of an issue. Arguments center around longevity (wear causing sloppiness over time) and manufacturability (tolerance stacking causing problems). Note- the shaft is custom so we won't use a commercially available spline therefore it needs to be able to be made affordably by a competent machine shop. The ID of the collar will most likely be EDM machined.
What is typically favored in industry practice? Useful resources specific to this subject?
Joa
Joa
RE: steering collar on shaft- theory
There's one more option to consider. Take a look at Kerk and similar high-lead leadscrews with plastic nuts. The nuts are split like a collet, and equipped with a taper and spring- loaded collar that takes up any slack developed in service. There's no reason the same idea couldn't work with a spline or a tang, if you need to minimize backlash. There may be patent protection to consider.
Flats and polygonal stock can work for light torques, but consider the extra stress induced in the collar by the radial force components.
You need to evaluate the design in light of the torque to be transmitted and the friction that's allowable to slide the collar.
Mike Halloran
Pembroke Pines, FL, USA
Is this for a nose gear application?
B.E.
http://www.generalpolygon.com/apps.htm
http://www.stoffelpolygon.com/
http://www.wisconproducts.com/polygon.html
http://
http
This one is for quick release but, is for a steering system.
Good luck.
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
Yes, a nose gear.
Thanks again.
Joa
