Pipe fabricated with ends milled for horizontal deviation
Can anybody help me?
How can I to verify if a installed piping system it is safe, when for a change horizontal direction in a section, was made joining both ends pipes milled for obtaining a deviation of 11 horizontal degree without the use of any fitting. The dates of pipe are:
24”Ø, 0.875” wall thickness, Design pressure: 739 psi, Operation temperature: 174 degree F;
And if the installation is no safe, what must I do?
RE: Pipe fabricated with ends milled for horizontal deviation
To my knowledge this doesn't require any higher thickness than straight pipe.
In ASME B31.1 you find the stress intensification factor for miters, that however matters only for expansion stresses.
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
You really need to pay attention to which Code the piping is designed to.
first and formost, the main issue will be the code and all of the design conditions.
