capacative sensing
capacative sensing
posting for another engineer who is looking for techincal information on how capacative sensors work. Links to discussions, white papers or sites.
RE: capacative sensing
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
One of the toughest parts is getting the RC happy under a widely varying ambient and converting the generally non-linear RC into a linear result.
Gunnar Englund
www.gke.org
Wow that's a cheap keyboard!! How'd it work? Would you do it again? Why would water and dirt "break it" (should be distinguishable)? What sheeting did you use?? How much of a pain in the butt was production? Did the huge freakin 50/60hz on the finger confuse everything??? Huh Huh? Tell me!
The water and dirt could esily seep in under the protective film. I guess that this could be taken a lot further. First thing would be to use some adhesive between cover and PCB to seal off humidity.
Gunnar Englund
www.gke.org
Though maybe not, because the capacitive, (as apposed to the capacAtive method), allows no moving parts >-> failure. I have seen so many membrane keyboards take down industrial equipment!
What is needed is something that describes (white paper?) on contactless sensing using capacitive sensing. Itsmoked touched on it but need more detailed information if possible
The best you will find are touch sensor IC maker's data sheets. (last link below)
http://www.edn.com/article/CA498777.html
http://w
http://www.flashwebhost.com/circuit/touchcpo.php
http://
http://kitsrus.com/pdf/k137.pdf
http://www.qprox.com/products/qt1xxx.php
http:
