Epoxy degradation temeperatures
Hello everyone
I'm working on a way to coat epoxy with a low friction coating. Theoretically for this coating to work i need to do a thermal cure (thermal treatment)at about 200º C.
My main doubt at this moment is to know the maximum temperature of cure, for a Aluminium epoxy mold.
Best regards
Paul
Best regards
Paul
RE: Epoxy degradation temeperatures
There are fluorinated epoxies that should bond well with the surface of a normal hydrocarbon epoxy to give a low friction surface and also one that is easy to clean. I think there are patents on just such surfaces for anti-graffiti.
