Runin excel macros
Runin excel macros
Runin excel macros
I woul like to run a macro in Excel automaticaly in the following way (as an example): If the value in cell A1 is "x" run macro1; if it is "y" run macro2. Any body know if this is possible?
RE: Runin excel macros
You can call another macro from with a macro, so write your value check as a seperate macro that runs automatically, and calls the other two depending on the value.
